Killer AX1650 Info And Review
Discussion in 'Networking and Wireless' started by WhatsThePoint, Apr 27, 2019.
  1. Ultra Male
    Ultra Male Super Tweaker
    Are you sure you connected the antennas properly and firmly?
    jaybee83 and alexhawker like this.
  2. Dennismungai
    Dennismungai Notebook Deity
    Hey there,
    What version of the Linux kernel do you have installed and running?
    You can confirm this by running:
    uname -r
    According to Killer Networking, Linux support is confirmed via the iwlwifi-backports kernel branch.
    I'll be able to test and confirm this when the P775TM-R arrives as my configuration had this selected at check-out (from HIDEvolution).
  3. Aivxtla
    Aivxtla Notebook Evangelist
    It does work, I mentioned the same a few pages back, he never replied I assume he gave up?
    I installed an AX200 on an old Dell Latitude 7440 on Ubuntu 19.04, and those instructions worked, pretty much just a copy/paste job:
    https://support.killernetworking.com/knowledge-base/killer-ax1650-in-debian-ubuntu-16-04/
  4. TheReciever
    TheReciever D! For Dragon!
    Yeah gave up as I needed the laptop at the time, I havent checked the thread since it didnt say that I was quote or anything sorry about that.
    Running 5.0.0-15-generic.
    I tried updating to 5.1 and it broke graphics switching in Pop_OS which is more important, so I am going to install it in my Ranger as well as the t440p when I get the whitelist removed.
  5. Dennismungai
    BIOS whitelists are still a thing...in 2019?
  6. hacktrix2006
    Yep it's still a thing.
    Sent from my LLD-L31 using Tapatalk
  7. TheReciever
    To be fair the laptop is from 2013, but yes it still exists sadly lol
    That and I have to install Windows to install the BIOS too, some things were a little backwards but its overall a wonderful machine.
  8. Stollen123
    Stollen123 Notebook Enthusiast
    i had hard time to connect the 2 wires to the Card..but finally i managed to connect it correctly i guess ..on Dell notebooks you do have also to swith the colors on an Intel card..
    if the wires are not firmlly connected could this result to a slower speed? i thought if they arent connected corrected that there would be no speed at all.
    i would try again to connect firmly and see what will happen...any idea how to connect it firmly? any tools to use with that?
    is there a possibility that the card if defective? if so how to test that?
    thank you
  9. TheReciever
    The m.2 wifi cards are a pain to connect the antennae.
    I use a bottle cap or the flat end of a pry tool to get the pressure needed to get that 'click',
    jaybee83 likes this.
  10. Stollen123
    I re-connected the antennas properly and firmly and the results are great.. download speed is as it should be about 500Mbit/s and upload 200Mbit/s..and the speed of the card in the status shows 1Gb to 1.7 GBps
    thank you for your tips and hints
