Keyboard problems
Discussion in 'Dell' started by Wyoming88!, May 14, 2019.
  1. Wyoming88!
    Wyoming88! Notebook Evangelist
    So I own a Dell Latitude E5420 14inch. And my problem is I’m typing and it just moves the other part of the word to another line/word. How can I fix this.
    Specs of this system
    Intel core i5-2540M@ 2.60 (?) ghz
    8gb ram
    250gb ssd
    Windows 7 pro sp1
  2. custom90gt
    Are you accidentally hitting the track-pad when you type?
    toughasnails and alexhawker like this.
  3. alexhawker
    alexhawker Spent Gladiator
    This would be my guess as well.
    custom90gt likes this.
  4. Wyoming88!
    No this happens even when a external one is plugged in
  5. alexhawker
    Can you disable the track pad through the touch pad properties and see if the issue goes away? I've seen similar from a failing but not quite dead touchpad.
    If that is confirmed to be the problem, you can leave it disabled and use a wireless or USB mouse, or replace the palmrest assembly.
  6. Wyoming88!
    Ok. Thanks
