Keyboard problems Alienware 15 R2
Discussion in '2015+ Alienware 13 / 15 / 17' started by Tommy111, Nov 15, 2017.
  1. Tommy111
    Tommy111 Newbie
    Like many others I have problems with some keys not working sometimes. Does anyone have information about reseating the keyboard ribbon? As this seems to be the most common fix. Thank you.
  2. VICKYGAMEBOY
    VICKYGAMEBOY Notebook Deity
    Cable could be faulty if ur keys are not registering, just try reseating first, remove battery cable first, next the big cable black ribbon, use ur fingers, and slowly pull up both sides of lock mechanism.. and when inserting cable again.. make sure the lock is still lifted, and give some movement on ribbon, then press the lock both sides equally, if it doesnt work. get it replaced..
    Vasudev likes this.
  3. judal57
    judal57 Notebook Deity
    it happens to me and i fix it by unplug and plug again the keyboard cable. try it
    Vasudev and VICKYGAMEBOY like this.
  4. Vasudev
    Pm me your battery stats or even whatsapp me after returning from work.
    EDIT: The OP can use methods suggested by vickygameboy.
    Usually power reset can fix these glitches.
