Keyboard Not Workin HP Stream 14
Discussion in 'HP' started by giocondrix, Jun 15, 2017.
  1. giocondrix
    giocondrix Notebook Enthusiast
    https://www.amazon.com/gp/aw/d/B01JLCKP1Q/ref=mp_s_a_1_4?ie=UTF8&qid=1497561273&sr=8-4&pi=AC_SX236_SY340_FMwebp_QL65&keywords=hp+stream+14&dpPl=1&dpID=51Jiem+a91L&ref=plSrch
    The link above is the one of my HP laptop (14-ax020nr), it was fine during the last 6 months, and suddenly the keyboard stoped working, it started with a few keys, but now i can't even type my password, i had to use the on-screen keyboard to use it. Unfortunately i am away from home to test a usb keyboard, I'll do it on the weekend when i get home, but for the moment i have already tried the unistalling the driver option, and rebooting the machine, I have alse tested it in the pc BIOS and it doesn't work either.
    So my two questions are:
    1. Could this have a software fix?
    2. If the above is not possible, would this part be compatible??
    http://m.ebay.com/itm/Original-New-for-HP-Stream-14-z-14-z000-series-UK-white-keyboard-/361860865811?hash=item5440969f13:g:cKkAAOSwDiBZGrBk&_trkparms=pageci%3Aae590bd8-51d3-11e7-8777-74dbd180251f%7Cparentrq%3Aac12b58415c0a86be68e996cfffee785%7Ciid%3A3
    I've found this other part:
    http://m.ebay.com/itm/HP-STREAM-14-...3D232328509967&_trksid=p2056116.c100408.m2460
    This seems to be the exact replacement, but is more expensive than the other part... i'm on a bit tight budget at the time...
    Thanks for your help
