Keyboard Light Fix (Gary Key)
Discussion in 'ASUS Gaming Notebook Forum' started by ziddy123, Aug 27, 2010.
  1. Cristi_pitbull
    Cristi_pitbull Newbie
    So i've done some measuring on my n56vb, directly on the backlit ribbon slot and saw that it has a +(5v) but has no -(minus) ! I could do the -(minus) myself manualy but a friend sayd it's risky. So is it possible that the bios is responsable for this situation ? Is it electronicaly activated by doing the grounding? Cuz the keyboard works.. I've tested it with a 3v battery on +/-and it lights up! So the laptop is the problem... MAN!
  2. Cristi_pitbull
    So the keyboard works... I've tested with a 3v battery and lights up. The laptop is the problem ...It gives only 5v+ but no ground(minus-). This is for sure from...BIOS
  3. Cristi_pitbull
    Anyone? Help?
  4. Meaker@Sager
    1) It will have a port so they don't have to manufacture different motherboards for each model.
    2) It's very likely a firmware limitation by either the BIOS or the EC, there is also a potential for an option select that was done further down the line in the manufacturing process.
  5. Cristi_pitbull
    Hello!
    It is possible to find a full version of BIOS for this Mobo?
    It would be nice to unlock all the features.
    Thanks for the reply
  6. Meaker@Sager
    You can see if someone can unlock it for you.
  7. Cristi_pitbull
    And how can i do that, be more specific.
    Thank you
  8. Meaker@Sager
    I can't be more specific as I am not in the Asus bios modding community myself but I suggest you hunt down places that is happening and ask there.
  9. ViLeGlyph
    ViLeGlyph Newbie
    Are there any working links for ATK? All of the old links are dead. :(
    G73JH-A1
    RBBX05
    bios: 213
  10. C4RN1
    C4RN1 Notebook Consultant
