Keyboard LED Lighting
Discussion in 'Sager and Clevo' started by autumnscarf, Jan 13, 2018.
  1. autumnscarf
    autumnscarf Newbie
    I just got my N850HP6 in the mail and I like it quite a bit so far. However, I'm a little confused about how to deal with the keyboard LEDs. I know you can open the control panel with FN+NUM/ but my settings don't stick after I close the window, just when the window is open. Also, is there a keyboard shortcut for turning the LEDs off?
  2. TurbodTalon
    TurbodTalon Notebook Virtuoso
    Congratulations on your new beast. After you change the LED setting to your desired color, are you hitting 'Save' on the bottom/right of the control panel? If so, does 'SAVE DONE' briefly appear and then disappear when you save?
    I am not sure about your second question.
  3. autumnscarf
    autumnscarf Newbie
    Ah, a couple of reboots mysteriously fixed the problem. I guess it had something to do with the control panel. Thank you though!
    Still looking for info on a keyboard shortcut for turning the LEDs off, but it's ok if there isn't one since the panel saves when I close it out now.
  4. aIex
    aIex Notebook Consultant
    In FlexiKey panel, there should be "Save" button in the bottom right corner. Shortcuts (all Fn + NumPad):
    Fn + / = FlexiKey Panel
    Fn + * = On/Off
    Fn + - = brigthness down
    Fn + + = brightness up
    Fn + 7 / 8 / 9 = zone on/off left/mid/right
