keyboard backlight control on clevo P775DM3(-G)
Discussion in 'Linux Compatibility and Software' started by giostark, Jan 22, 2018.
  1. giostark
    giostark Notebook Enthusiast
    Hi there ,
    Im trying to figure out how to make it work under my Arch linux (last build).
    https://bitbucket.org/tuxedocomputers/clevo-xsm-wmi
    The Arch proper modules didnt work . Also the last provided by tuxedo seems not work. Any of you , maybe , succeeded to make it work?
    Unfortunately when i type "dmesg | grep clevo" no model is displayed.
    As reported my model should be compatible :
    P775DM3(-G) Clevo P775DM3(-G) TUXEDO XUX707
    But my brand is Santech so i didnt know if some small customization can make the difference for the final building.
    I reported the request for add my model but unfortunately still nothing happens.
    https://bitbucket.org/tuxedocomputers/clevo-xsm-wmi/issues/33/p7xxdm3-g-clevo-p775dm3-model-support
    Tnx anyway.
  2. giostark
    Hi there,
    I finally figured out how to make this work:
    Finally... thanks to the community. Im using arch so having problems compiling from the source here provided https://bitbucket.org/tuxedocomputers/clevo-xsm-wmi/overview I managed doing so:
    Installing the module and the utility provided on Aur.
    https://aur.archlinux.org/packages/clevo-xsm-wmi-dkms/
    https://aur.archlinux.org/packages/clevo-xsm-wmi-util/
    Then I downloaded the source from here and uncompressed the tuxedoxxx.zip and modified as follow. I found that the description of my model in dmidecode have a "dash - " before the "parenthesis ( " and not after as stated in the clevo-xsm-wmi.c file.
    So as suggested by devstructor devstructor here : https://bitbucket.org/tuxedocomputers/clevo-xsm-wmi/issues/41/pa71hp6-not-working I added the following lines between the model listed near the end of the file.
    Code:
           .ident = "Clevo P7xxDM3-(G)",
            .matches = {
                DMI_MATCH(DMI_PRODUCT_NAME, "P7xxDM3-(G)"),
            .callback = clevo_xsm_dmi_matched,
            .driver_data = &kb_full_color_ops,
    After this i changed always in the same file clevo-xsm-wmi.c this as suggested by bolog here https://bitbucket.org/tuxedocomputers/clevo-xsm-wmi/issues/20/sager-np8174-not-working :
    Code:
    CLEVO_XSM_DEBUG("%0#4x  IN : %0#6x\n", method_id, arg);
    status = wmi_evaluate_method(CLEVO_GET_GUID, 0x01,
       method_id, &in, &out);
    changed to:
    Code:
    status = wmi_evaluate_method(CLEVO_GET_GUID, 0x00,
    After those small modifications I copied the modified module substituting the module provided in Aur: sudo cp clevo-xsm-wmi.ko /lib/modules/$(uname -r)/kernel/drivers/input/keyboard/clevo-xsm-wmi.ko
    Now the back light work.
    Aivxtla likes this.
  3. Dennismungai
    Dennismungai Notebook Deity
    Hello there,
    Tuxedo computers have been refactoring the code of late, and you should be using this version: https://github.com/tuxedocomputers/tuxedo-keyboard
    Their documentation is a work in progress, but I'd recommend taking the DKMS route: https://gist.github.com/Brainiarc7/...ght-control-by-tuxedo-keyboard-wmi-handler-md
    Steps:
    mkdir -p ~/clevo && cd clevo
    git clone https://github.com/tuxedocomputers/tuxedo-keyboard
    cd tuxedo-keyboard
    make clean
    sudo cp -R . /usr/src/tuxedo_keyboard-1
    sudo dkms add -m tuxedo_keyboard -v 1
    sudo dkms build -m tuxedo_keyboard -v 1
    sudo dkms install -m tuxedo_keyboard -v 1
    Perhaps an Arch maintainer should create this package for the AUR? That'd be awesome :)
    Aivxtla and Vasudev like this.
