K53ta-bbr6 Cooling Mods
Discussion in 'Asus' started by gumba213, Sep 4, 2011.
  1. ghost_207
    ghost_207 Notebook Enthusiast
    thanks for the info
  2. gumba213
    gumba213 Notebook Consultant
    removed the heatsinks on top of the heat pipe, they were causing more heat. also removed the copper heat sinks off the gpu heat pipe, and placed them on the aluminum plating like before. also kept the aluminum heatsink on the gpu but turned it 90 degrees so the fan could blow on the coils more effectively. there was too much going on and it was causing more heat, removed a little and we are back down to 77C max cpu temps while playing dues ex
    it appears dx has a stutter bug issue and I'm noticing it pretty bad in my gameplay very annoying
  3. HTWingNut
    HTWingNut Potato
    Hmm, interesting that it was raising temperatures by putting the heatsinks on the heatpipes. Maybe the heat was dissipating along the pipe but didn't have the fan to cool it off effectively.
  4. gumba213
    the additional heatsinks on the heat pipe basically acted like an air damn and wasn't letting air past it. The computer felt warmer to the touch, and air wasn't escaping properly. this should prove that the front air vents are actually very functional. It should be noted that the pc now feels considerably cool again.
  5. gumba213
    Final Product updated on OP, I will add to it as necessary.Let me know if you do any modding of your own, I would like to see the results. Thanks - Steve
  6. Disgustipated
    Disgustipated Notebook Consultant
    If you drop Anisotropic Filtering down to 4x, you'll get about 5 FPS gain with almost no loss in image quality. Also, if you have an external monitor, you can get better performance @ higher resolution with antialiasing off than at lower resolution with AA on.
  7. HTWingNut
    HTWingNut Potato
    Aniso gives you clarity at a distance but not sure if it's really all that necessary in Deus Ex.
  8. logos2000
    logos2000 Newbie
    This looks pretty cool. Are any of the visual distortions corrected or improved with better cooling as well? I still can't get over the grainy, compression-type of look that this laptop gives on certain colours (and poor lcd... I can see the "matrix" of pixels in the monitor, reminiscent of old VGA monitors; which further contribute to graininess) I may return it for a laptop with just the plain 6520g.
  9. Rorschach
    Rorschach Notebook Virtuoso NBR Reviewer
  10. Sxooter
    Sxooter Notebook Virtuoso
    Have you updated your BIOS?
