K5 PRO (Gummy Paste/ Thermal Pad replacement) Question
Discussion in 'Hardware Components and Aftermarket Upgrades' started by RomanQuadra, Nov 30, 2021.
  1. RomanQuadra
    RomanQuadra Notebook Enthusiast
    Hello!!! In about 3-6 months I think re-open the cooling chamber in my ASUS G513QY laptop to repaste my CPU and GPU. When I will do it, will have to redo K5 PRO which I used on my VRM and VRAM silicones? Thank you!
  2. Tech Junky
    Tech Junky Notebook Deity
    Paste is paste and pads are pads. Pads should be fine if you release the heat sink slowly.
    As to the paste I switched to a graphite pad on my laptop and it's working great w/o the mess of cleaning / reapplying in the future.
    https://www.amazon.com/dp/B08BL3SCWH
    I've been using these on my server for a couple of years now and idle @ 75F and under load 100F maybe 130F for an extended load.
    Laptop on performance mode idle ~50-60C CPU / 50C GPU and under load 80C CPU / 80 GPU max. If I kick to silent mode they both drop to 40C.
  3. MrBorsky
    MrBorsky Notebook Enthusiast
    Yes, you will need to reapply liquid thermal pads, but K5 Pro isnt best option, best are Laird.
  4. tilleroftheearth
    Any links, recommendations for Laird?
  5. MrBorsky
  6. custom90gt
    K5 is just fine for your VRM and VRAM. I would replace it because it's easy and will ensure that there are no gaps from opening it up.
    K5 has a "higher" conductivity than the first Laird link (not that I really trust it), unless there is some extensive testing I would just stick with it.
    Papusan and dmanti like this.
  7. MrBorsky
    Yep, first month K5 Pro are good, but after 1 month it degrades and becomes like a plasticine. =)
  8. dmanti
    dmanti Notebook Enthusiast
    Wouldn't a clay-like consistency, similar to a thermal pad, be an improvement?
    Though, that'd probably also form cracks/voids, which wouldn't be good.
  9. RomanQuadra
    As I been informed up to 1mm K5 Pro is good.
    Above it better go thermal pads.
  10. custom90gt
    I mean I've ran it for over a year on my XPS without that issue. I'm not bridging a huge gap, just around 1.25mm, but it works just fine. I've had tons of K5 applications without it drying out.
