Just upgraded my GT73VR to EC Firmware 17A1EMS1.112
Discussion in 'MSI' started by Phoenix, Jun 19, 2017.
  1. Phoenix
    Phoenix Super Tweaker
    I found a newer EC Firmware on the GT73EVR 7RE TITAN Drivers page
    So me being curious George and since the EC Firmware for the GT73VR Titan Pro is still on the old .108 I thought heck, lemme try it since the laptop models are essentially the same
    1) Download the EC Firmware from here = https://www.msi.com/Laptop/support/GT73EVR-7RE-Titan.html#down-bios
    2) Extract the ZIP file j00 just downloaded
    3) Disable your AntiVirus and exit all programs
    4) Right click on ECWIN.BAT and choose Run As Admin
    5) Press Y to confirm
    6) Your fans will start spinning :rolleyes:
    7) After the EC firmware has been flashed, the laptop will shutdown
    8) Unplug the power cable and wait for 30 seconds
    9) Replug the power cable and turn on your laptop
    10) Enter the BIOS again and load setup defaults
    11) Save and exit then shutdown the laptop then reset your EC Firmware:
    12) Enter BIOS again and reconfigure everything the way it was before
    13) It is recommended to set the VR Current limit from the stock 0 to 400 which shows as 100A to avoid CPU Throttling
    Note: I am not responsible if you brick your laptop, do this at your own risk. if you are not acing any issues with your laptop currently, don't even bother. I did it because I like to always have the latest and greatest
    Be Brave! Be Like Phoenix! [​IMG] [​IMG]
    infex and RalfTech like this.
  2. SoldierRBT
    SoldierRBT Notebook Geek
    Did the fan curve change? Can you post a photo of the CPU and the GPU fan curve? Select Advanced and select default.
  3. Phoenix
    Please post your for comparison
    RalfTech likes this.
  4. Falkentyne
    Falkentyne Notebook Virtuoso
    Phoenix, that doesn't reset the EC Firmware.
    In order to reset the EC, you either have to unplug the battery for 30 seconds, or you need to press the underside pin hole with a paper clip for 30 seconds (both after unplugging the AC cord).
    While it may still work, the EC may not be fully reset....
    Phoenix likes this.
  5. Phoenix
    I did unplug the power cord for 30 seconds as stated in the guide. Do I need to press the button under the laptop also? and for how long?
  6. Falkentyne
    That button is for resetting the EC. It's one or two presses of it for 30 seconds. SVET included that in his instructions for his Bios mods. Resetting the CMOS (as you already know) is holding down the main power button for 40 seconds.
    There's no harm in resetting the EC. Usually a reset is only needed if something strange starts happening, like fans don't reply correctly or FN key isn't working, but it's sure much easier to do than a full CMOS reset. If it means anything, I did reset the EC long after my failures at making Command Rate 1 work a second time, and stopped trying (i should have tried right after resetting the EC. I just did it for the 'heck of it') but as soon as I tried it again last night, CR 1T worked right away (<15 seconds to POST), unlike before. Might be luck or placebo, and going to be smart and not try to "test" my theory.
    it would be nice if there were a changelog. Do you (edit) still have the "black screen" dGPU bug after "Load Defaults ->iGPU->dGPU->black screen?"
  7. SoldierRBT
    These are the default fan curves for EC .108
    Looks like the only change was the CPU fan curve.
    Phoenix likes this.
  8. Wazabi
    Wazabi Notebook Enthusiast
    Do you think it would be save to install it on a GT73VR 6RE ?
    Thanks!
    Edit: Just installed the EC Bios on my laptop, no problems so far. (also got the new CPU curve)
    Phoenix likes this.
  9. specialist7
    specialist7 Notebook Evangelist
    Yeah so it seems everything is the same on the GPU side.
    For the CPU the fan speed still the same at 65% at high temps, 20% at low temps.
    The change happens when they ramp the fan speeds for the CPU to 34% earlier, and added the 40% at mild load.
    So instead of a 30% -> 35% -> 55% jump its a 34% -> 40% -> 55%.
    Theoretically this would make the laptop slightly louder at same temps 34% (vs. 30% rpm) but the added 40% rpm will keep it cooler and maintain the temps (should keep the sound overall lower) till it kicks up to 55% when they're both at the same level. (Thats my guess lol).
  10. saturnotaku
    saturnotaku Notebook Prophet
    Where is the EC reset pin hole on the bottom of the notebook?
