Issues with Battery saying Plugged, Charging but in reality not charging!
Discussion in 'Sager and Clevo' started by gab1, Aug 30, 2018.
  1. gab1
    gab1 Notebook Enthusiast
    Hello guys I have a Clevo P670RS-G, the specs are bellow:
    Avell G1746 Iron
    Motherboard: Clevo P670RS-G (P65_67RSRP)
    Processor: Intel Core i7-6700HQ 2.6 GHz, Turbo Boost 3.5 GHz
    Video Card: Nvidia GTX 1070 (Mobile) 8 Gb
    Memory: Kingston 9905663-007.A00G 2x16GB SODIMM DDR4 clocked @ 2133 MHz
    SSD: Samsung 850 Evo 500GB
    SSHD: Toshiba Notebook SSHD 2.5" 1TB
    And my issue started a while ago (1 month or something) after I changed my CPU and GPU thermal paste (all cables checked and reput correctly) my battery stopped charging and even it is saying Plugged in, Charging but it doesn't charge. I already changed the battery and the PSU, formated and tried everything, what could that be?
  2. Chastity
    Let the battery drain all the way, then recharge it so the battery calibrates.
  3. gab1
    It drained and it simply doesn't charge. Just 0% Plugged, charging but nothing happens!
  4. Prostar Computer
    Probably a main board fault. Can you see any problem with the battery terminals on the board?
  5. Support.1@XOTIC PC
    Support.1@XOTIC PC Company Representative
    What type of Thermal paste did you use? If it was LM if any got on the mainboard it may have caused a short.
  6. gab1
    Last time I checked didn't see anything abnormal, will open the case take a picture and post here so you guys can check it out too. Any idea of how to solve it if it is on the motherboard?
    This is the Paste I used: https://eu.coolermaster.com/en/cooling/thermal-compound/mastergel-maker/
  7. Meaker@Sager
    Could have been static discharge while you were working got the charging circuit.
  8. gab1
    Any solution to that? Or it is what it is and nothing I can do?
  9. Support.3@XOTIC PC
    Support.3@XOTIC PC Company Representative
    Not electrically conductive, so not likely the issue. I'm going to say something else caused a short while you were in there is the most likely issue. Probably need to replace the board if that's the case.
  10. gab1
    So I'll have to stay with the computer like that, don't think the brand will replace the motherboard which means giving me a "new" computer.
