Issue with speakers after disconnecting headphones
Discussion in 'Sager and Clevo' started by shkipper, Dec 20, 2012.
  1. shkipper
    shkipper Notebook Enthusiast
    Hello everyone
    I have an issue with my laptop, i have a branded laptop etc etc
    Everything basically works fine except, i bought headphones and when i put headphones jack into the laptop i hear music from the headphones as it should be,but when i disconnect the headphones the sound doesn't return to the built in speakers in the laptop, ONLY after restart i can hear sound back from speakers, untill i connect headphones. It really disturbs me as i want to be flexible by connecting and disconnecting the headphones etc ... any idea how could it be?
    I have operating system Windows 8
    The code of my laptop is X-book 18cl37 if it says anything more ...
    Another issue maybe it has something to do with is that my touch sensor keys on the top are not working after installing the windows 8, altough i installed drivers "Hotkey AP 3.3040" they still dont work ... but yeah it doesn't disturb me that much as the sound, which i really need.
    Also to notice i have Realtek Audio HD Manager and when i jack out it notices ti and says that my headphones disconnected, so that is not like there still connection or something, and i see that the music is playing.
    So any idea what it could be?
    Thanks in advance
  2. Prostar Computer
    Are you sure the playback isn't simply being halted/paused? A lot of smartphones will pause playback when you remove any aux device. If your sound non-functional altogether after unplugging, go into your volume control options and your playback devices menus, and make sure nothing is muted or disabled.
  3. shkipper
    Yes, it is deffinetly plays the song, and its not a smartphone it is a notebook, and there no any of the song coming from the speakers! I see the sound moving when i hit on the sound icon, i see the beats or how you call it, that it bounces that it is playing something. But as i said if i'm plaing the game it is the same ... sound is there but it is not going to the speakers.
  4. Prostar Computer
    Ah, haha I was just using smartphone playback functionality as an example. Okay, got it; playback is still happening, but no audio output after unplugging earphones.
    Did you refer to the screenshots I posted? If you're running Windows 7, you should find something similar to those by right clicking on your sound icon, and then selecting Playback Devices or Open Volume Mixer.
    Aside from checking those settings, try muting and then unmuting (not a word, I know) your audio. But if that doesn't work, refer to the screenshots there and see what your audio levels and options are like.
  5. shkipper
    Yes, I've refered to the screenshots you posted and everything is set as on the screenshots, if it would be muted or something i wouldnt see the playback but i see it the green level bar is jumping ... it is so annoying and i dont know why this happens, can it be cuz of some broken drivers? ALthough i reinstalled the Realted HD audio stuff ... Really dont know what else could be causing this issue ...
  6. Prostar Computer
    Try a clean install of the driver. Go to your Device Manager, and uninstall the sound driver from there (under Sound, video and game controllers). Right click > uninstall driver > confirm.
    When you re-install the driver, use the Add New Hardware wizard within Windows to manually install the driver instead of installing from the setup utility.
    Hopefully that works. :)
