Is wireless N worth it?
Discussion in 'Networking and Wireless' started by Zydan, Sep 7, 2007.
  1. Zydan
    Zydan Notebook Evangelist
    I have a Linksys Wireless G now, I currently got a new laptop with Intel wireless N.
    I'm wondering if it's worth the switch to a broadband - N router, will I see the diffference?
    Anyone have any experience with or advice for I'd appreciate it. Thanks!
  2. Johnny T
    Johnny T Forum Moderator Super Moderator
    You will see a slight difference becasue of the increase bandwith of wireless N. But then again this all depends how fast your broadband is.
    I would say stick with G:D
  3. Sykotic
    Sykotic Notebook Evangelist
    Do you do alot of file sharing with other computers on your network?
    If all you do is internet based then think about this: Wireless "G" supports 56MB/Sec and your internet is ? Unless you have a 56MB/sec or higher its not going to make that much of a difference.
    Another thing to think about, most web pages are less than 500k, and even if you have a 500k/sec connection then it will take 1 whole sec to see the web page. How fast can you read?
    GL
  4. Reezin14
    Reezin14 Crimson Mantle Commander
    In theory g is 54Mbps, and wireless n 108Mbps,so what ever your surfing at now you can expect it to double as well as the range that you can connect. Wireless n is an improvement over g but the IEEE hasn't ratified as of yet so the device you have now might not be compatible with the final draft.It does depend on your connection speed,but as long as it not Dial-up you should be fine.
  5. syberdave
    syberdave Notebook Enthusiast
    Does anyone notice a significant improvement in range? I'm living on a college dorm and my G router doesn't penetrate the floors very well.
  6. Sykotic
    Dont actaully expect your internet surfing speed to double, unless you have a 108Mbps internet connection. Most internet connections are less than 10Mbps. <--- no matter how fast your router is, you will not increase your internet speed. Just network speed.
  7. Reezin14
    You must remember that 802.11n uses MIMO(multiple input,multiple output).There for increasing the the speed.Also we're talking Mega bits not Megabytes. Mb,MB
  8. Sykotic
    8 bits = 1 byte.
    54 Mbps = 6.75 megabytes p/s
    to double that would be 12 megabytes per sec.
    If you get 12 MEGAbytes per sec, can I be your friend?
    wait... how many servers can upload that kind of bandwidth to just 1 user.
    Your network speed will double and it you had a 12 MEGAbyte per sec internet connection it would also double.
    what was I thinking, 6.75 * 2 == 13.5 difference is 1.5 MEGAbyte per/sec. Still who has a 13.5 megabyte p/s internet connection?
    Verison FioS, I think offers a 40 MEGAbit connection using fiber optic. Not sure of price or availiblity
  9. StormEffect
    StormEffect Lazer. *pew pew*
    Oh my dear boy, I don't think you've ever really seen how fast a great server can spit out data. :D
    Regardless, G has more than enough bandwidth for your internet connection. Only get N if you really NEED slightly longer range and transfer lots of files between computers over your network. Don't get N if you just want to use internet and it is already working fine.
  10. Reezin14
    Sykotic,that's just what I'm talking about network speed,not internet speed,I could've worded it different.So we're on the same page.
