Is there supposed to be a "blank" in the Smart Card reader?
Discussion in 'Dell' started by 1138, Oct 11, 2007.
    1138 Notebook Geek
    It does have one for the PC card slot, but not one for the Smart Card reader. I guess that's the way it's supposed to be. Thanks.
  2. PhoenixAG
    PhoenixAG Notebook Consultant
    Wow. This thread is unbelievable. The terminology is all over the place here. You guys are using terms interchangeably and meaning very, VERY different things.
    All our Dell laptops have Express Card readers. They are where you put the remote, if its not already in use. It comes with a blank.
    Then, we also have all in one memory card readers. They are the ones used to read SD/MMC/MS cards. And yes, my 1420 does have a blank one in the slot.
    We don't have any Smart card readers. Smart cards are different. Nor do we have any PCI Express cards accessible from outside. We have a GRAPHICS CARD inside, which fits into the PCI Express slot. However, this is not at all accessible from the outside.
    There, hope this solves the confusion.
  3. 1138
    1138 Notebook Geek
    The D630 has a PC card slot, not an Express Card slot.
    The D630 does have a Smart Card reader. The Inspirons don't.
  4. Dell C.A.
    Dell C.A. Company Representative
    Hello,
    The Inspiron 1720 does not have a Smart Card slot. Smart Cards are used for security. You could think of it like a key card to gain access to the computer. You can Wiki more information on Smart Cards for a more detailed description.
    Example of Smart Card
    This memory slot is for SD cards. Same type of function as USB keys, just a different interface.
    Memory card slot for 1720 system
    I hope that this clears up any confusion.
    Best regards,
    Richard B
    Dell Online Community Outreach
  5. Dell C.A.
    Clarification:
    The D630 has a PC Card slot. The slot can use an ExpressCard but with an adapter. Our wireless (Verizon) card is an ExpressCard, which includes the adapter.
    Example of adapter:
    My apologizes for not being clear on this. Thanks for pointing this out.
    Regards,
    Richard B
    Dell Community Outreach
  6. J-Bytes
    J-Bytes I am CanadiEEEn NBR Reviewer
    Yeah, it's a what's-it-called... An express dummy.
  7. SJSMR2
    SJSMR2 Notebook Guru
    I have 2 blanks also one in the memory card slot and one in the smart card slot.
Similar Threads - supposed blank Smart
  1. alvinkhorfire
    16
    788
