Is there anything better out there, than this?
Discussion in 'What Notebook Should I Buy?' started by awaisuk, Apr 18, 2013.
  1. awaisuk
    awaisuk Notebook Deity
    Hey,
    So I am thinking of getting the Dell latitude e6230. The reason for that is, it is 12.5" and portable to carry around.
    Here is the configuration that I am thinking of getting:
    Intel Core 3rd Generation i5-3320M Processor
    256GB 2.5 inch (SATA3) Mobility Solid State Drive
    4GB Dual Channel DDR3 SDRAM at 1600MHz
    12.5inch HD (1366x768) LED-backlit LCD Panel with HD Camera and Microphone
    Backlit Keyboard
    6 Cell Lithium-Ion Primary Battery
    This is what I am getting for close to $800, and it a refurbished computer.
    The only thing is, that the screen quality which doesnt seem very good
    Is there anything out there with better screen and even lighter than this with the same processor speed?
    Thanks.
  2. Tmets
    Tmets De-evolving to Amoeba
    A Lenovo X230 is a similar laptop and has an IPS screen. Look at the Lenovo outlet, you might find a cheap one.
  3. Jarhead
    Jarhead 恋の♡アカサタナ
    There's also an HP Elitebook in this size and power range, though iirc it's just a regular TN panel similar to that Latitude. For a better-quality panel, the X230 with IPS upgrade is probably your best bet.
