Is Pcmcia Dead?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by maiki, Jul 16, 2011.
  1. T1mur
    T1mur Notebook Guru
    With chipsets newer than ICH8 you can use USB 2.0 audio devices for most tasks. Unless you need MADI, but then you are likely using a more expensive laptop, too, which should still come with ExpressCard.
    Intel put its energy into Light Peak/Thunderbolt, which effectively is the same as ExpressCard, just in a more convenient, but also more expensive cable form.
    Personally I use ExpressCard for eSATA and made Apple exchange my Macbook Pros over the course of 2 years repeatedly until it was at least usable without data corruption. Still I must not touch the MBP with external grounding while transferring data to keep the EC port from dropping out.
    Once USB 3 and Thunderbolt are widely spread both FW and ExpressCard will only be offered as external adapters to keep "legacy" hardware going.
