Is my optical drive Blu Ray or not?
Discussion in 'Asus' started by Cor, Nov 24, 2008.
  1. Cor
    Cor Newbie
    I have the M50SV model AS030G, as sold in the UK. (Vista Ultimate SP1)
    When I purchased it I confirmed that it was the Blu Ray model, & had a HDMI out.
    I borrowed a Blu Ray to try, & couldn't get it to read at all.
    After searching I realised that I didn't have the WinDVD software required.. Called up the retailer, & was informed that "cyberlink DVD suite power2go" was supplied & would do the job.
    This did not help with playing my Blu Ray.
    The optical drive installed is the HL-DT-ST DVDRAM GSA-T40L ATA Device.
    I've searched, & not been able to get any info as to if this is indeed "Blu Ray" compatible.
    Blu ray is not mentioned on the notebook or drive. But "HD Vision" is.
    Do I need WinDVD, or have I been sold a blu ray notebook that is not?
    Sorry for rambling. Any help would be greatfully received.
    Cor.
  2. David
    David NBR Random Reviewer NBR Reviewer
  3. Cor
    Cor Newbie
    Thanks, but wouldn't that invalidate the warranty?
    Also, what should I be looking out for in the drive?
    I worry that as Blu Ray is not written on any visible component of this notebook, that it is maybe not Blu Ray at all. :mad:
    I live in hope that software will cure me.
    Cor.
  4. Bryanu
    Bryanu Notebook Deity
    Just eject the drive, does it have 2 laser heads in it?
    My g50vt-a2 has 2 laser heads in it...
    Also says blue ray on the drive itself
  5. David
    Nope, only removing your CPU and GPU would void your warranty ;)
    It's really the fastest way to check if your optical drive is a blu-ray player or not.
  6. kanehi
    kanehi Notebook Deity
    Do you have the Blu-ray icon on the drive cover? If not then it isn't.
  7. Daskid
    Daskid Notebook Consultant
    How about trying to play a Blu-Ray Disc? If it plays, then good for you. If not, then you know what it is. I think that would pretty much solve the problem.
  8. Cor
    Cor Newbie
    Thanks for the replies.
    No Blu Ray or logo on the drive.
    I did try to play a blu ray disc, this is how I discovered my problem.
    After extensive searching, I had hoped that it was down to missing software (WinDVD), which was not supplied.
    It now looks like I've been sent a wrongly spec'd notebook.
    I'll get back to the Asus Retailer and see what they say.
    Thanks again.
    Cor.
  9. Freakish123
    Freakish123 Notebook Consultant
    Yeah the model number you gave would indicate a DVD RW type device.
    As far as i know the Bluray players doing the rounds are listed as Optiarc-5500, + the fact it does not have the logo on the drawer drive, and the other stuff you covered, I would say DVD only.
  10. [OgV] Audie
    [OgV] Audie Notebook Enthusiast
    I ordered my G50VT A2 from Xotic PC without Blue Ray but my drive cover still says Blue Ray. Couldn't they have just pulled out the optical and replaced it with a non blue ray and never changed the cover?
