Is making a recovery CD necessary?
Discussion in 'Windows OS and Software' started by davidt1, Jun 4, 2010.
  1. davidt1
    davidt1 Notebook Evangelist
    I bought a laptop without CD-ROM. I was gonna buy an external one to make a recovery CD, but there is already one on the hard drive. There is no need to make a recovery CD, if you can recover from the hard drive. What do you think?
  2. lbohn
    lbohn Notebook Consultant
    If your hard drive fails you won't be able to (re)install the OS on a new drive using the recovery partition/image located on the original, dead drive. But you could with Recovery CDs ...
    --L.
  3. Joel
    Joel coffeecoffeecoffeecoffee
    Yeah, lbohn makes a good point. You could even just borrow someone else's if you need to. Or if you have an old IDE or Sata drive, just buy an enclosure for it.
  4. davidt1
    I have a laptop hard drive with an external enclosure. Are you saying I can make a recovery CD on an external hard drive?
  5. kosti
    kosti Notebook Virtuoso
    I think he meant get an external enclosure for an optical drive. But you can just make a bootable XP install on your external hard drive if you want. You will need an original CD though.
  6. Joel
    Yeah, I meant optical drive. ;)
  7. ScuderiaConchiglia
    ScuderiaConchiglia NBR Vaio Team Curmudgeon
    You don't even need an enclosure. All you need is a bare CDR/CDRW drive and something like one of these:
    Micro Center - Bytecc USB 2.0 to IDE/SATA Adapter BT-300
    There are tons of these sorts of adapters on the market. I picked one up with an external "wall wart" power supply for $14.
    Gary
  8. newsposter
    newsposter Notebook Virtuoso
    it takes all of 15 minutes to make recovery discs......
    For every hard drive that lives 5+ years, and every user that claims they have never had a drive failure, there is another drive that dies in 90 days and another user that 'enjoys' 100% data loss.
    There is no way to tell which kind of drive you have or what kind of data loss you might eventually suffer.
    How do you like those odds?
    Make your recovery discs and do your backups.
  9. davidt1
    OK! Making recovery discs right now, but it's gonna to take a lot more than 15 minutes on my netbook.
  10. ScuderiaConchiglia
    Time well spent nonetheless.
    Gary
