Is it worth waiting for y410p sli?
Discussion in 'Yoga, IdeaPad & Essential' started by carterofearth, Sep 23, 2013.
  1. Jobine
    Jobine Notebook Prophet
    Here are the upgrades i recommend, and NOTHING ELSE:
    - 95% Gamut screen (essential for design, but waste of money if for gaming only)
    - Thermal Compound IF AND ONLY IF you are scared of doing it yourself
    - Samsung EVO 840 SSD, size of choice
    - 16 GB RAM, IF AND ONLY IF you absolutely need it. 8GB is fine for 95% of users though.
    - Warranty extensions if you need any, i personally don't.
    That's it. Everything else is just a gimmick to buy accessories you can find cheaper elsewhere.
  2. carterofearth
    carterofearth Notebook Enthusiast
    K, good stuff.
    I chose the 120GB Samsung 840 (1300 budget), if I get around to being able to upgrade it in the future, how hard is it to change the main SSD and/or the mSATA?
  3. Jobine
    1. Changing the Main SSD/HDD is not too hard, however many people (such as myself) broke a beg on their way on doing it. This laptop is built very snuggly, which is good for build quality but bad for openers. Hence why i recommend buying the SSD from Xotic so they can install it for you.
    2. The laptop does not use Msata. It uses M.2 (NGFF), which is PCI-e based and is not currently publicly availible. If you buy some Msata's from Xotic they just ship you a Msata caddy. Theres a reason i said
  4. Benchmade 42
    Benchmade 42 Titanium
    The Y410p @ $810 before taxes with GDDR5 GT 755m w/ quadcore haswell and hd+900 screen is a damn good deal for people looking for a potent gaming machine and has everything you need as a desktop replacement computer. It has an optical drive, card reader, hdmi port, usb 3, backlit keyboard and a decent touchpad and a decent tn screen.
  5. Jobine
    He's looking for a SLI model. 755M can't run games on ultra, unfortunately, but yes it is a great laptop for the price :thumbsup:
    And 14 inch is *NOT* a desktop replacement. 14 inch = portable.
  6. carterofearth
    IF the 14 inch model had SLI....I'd be all over that lol
  7. Benchmade 42
    The term desktop replacement meant that your current laptop can do what a pc tower can so of course it is a desktop replacement, it does not need to be a 15 or 17 to be a desktop replacement. I had an m11x r1 in 2010 and it was my primary pc and it replaced my desktop pc or my G73 at the time.
    Lots of people nowadays have their 11-13" laptops as their primary machine and using it as their desktop replacement. See the difference and what I mean now?
  8. Jobine
    Yeah. It would have poor battery life though, but that's not really a problem since you can swap the bays :)
  9. carterofearth
    If I'm not doing any super color intensive graphic work, would you recommend putting that extra $150 in an SSD rather than in the 95% gamut?
    I'd go from 129GB SSD to 250GB SSD with stock screen. Is the stock screen any good?
  10. Jobine
    Stock screen is good for 90% of people. Go with the bigger SSD.
