Is it possible to swap screen on GE76 ?
Discussion in 'MSI' started by ptt1404, Nov 21, 2021.
  1. ptt1404
    ptt1404 Notebook Enthusiast
    I am doing some research to swap my poor ge76 screen (auo978f) to 300hz screen (same ge76 but different ge76 code). I wonder since the laptop itself has same chassis, could it possible to recognize the new screen (same 40 pins, ep 1.3 lane) ? Thanks so much
  2. Tech Junky
    Tech Junky Notebook Deity
    http://forum.notebookreview.com/threads/laptop-screen-upgrades.816139/page-57
    AUO B173HAN04.9 (AUO978F)
    https://www.reddit.com/r/MSILaptops/comments/kg49tp/my_new_one_gl75_leopard/
    https://www.panelook.com/B173HAN04.0_AUO_17.3_LCM_overview_37192.html
    389.89(W)×238.31(H) ×3.5(D) mm
    eDP (2 Lanes) , eDP1.4 , HBR2 (5.4G/lane) , 40 pins Connector
    https://www.panelook.com/sizmodlist...]=1730&signal_type_category=70&st=E20&by=desc
    https://www.panelook.com/modelcompare.php?ids=42215,44168,45254
    If it were me I would aim for 1.07B colors for the best viewing. If you're looking for high RR then you're limited to 1 other 300mhz screen which would be the middle one in the comparison
    B173HAN05.1Code: AUO519D
    The 3rd one
    B173ZAN03.3Code: AUOA988
    Offers the higher colors but drops the RR to 120hz
    Your original screen is 60hz though so, any bump up would be better. There's trade offs when it comes to RR vs colors and brightness / contrast
    IMO 300hz just makes things somewhat blurry. 120hz will be sufficient depending on what you're doing i.e. gaming. Though I just spotted an issue with the high color model being that the pin pitch is 0.5mm and your OE / 300hz option here are 0.4mm. There's a way around the pin pitch issue with an adapter you insert into the cable path that's relatively cheap.
    There are a lot of games that are played when souring a new panel though to keep in mind. Dealers like to ship "compatible" models instead of the actual model you're looking for. I went through a couple of them when sourcing my replacement and it gets tiresome hunting down the proper panel. I ended up using kreplacement.com direct from CN to get the exact panel I was looking for. With FedEx express shipping it showed up within 4 days @ $150 total. The panel didn't cost much more than other sources that were domestic but, having been burned already it seemed easier to just go to the source rather than domestic. If you have the time to wait you can cut shipping costs.
    I was able to see both options listed on AliExpress which should indicate they're able to be sourced at least. There doesn't seem to be much of them on other sites though.
    ptt1404 and dmanti like this.
  3. ptt1404
    thank you so much SIR, you are my savior, knowing excatly what I am looking for! :D I see some people say I need to stick with my original screen that comes with laptop, otherwise it wont work, even risky to damages the mainboard components, which makes me nervous to swap :D
  4. Tech Junky
    You're welcome. If you take your time with it then it should be smooth. Make sure the cable is seated alll the way and don't apply too much pressure are the keys to success.
    ptt1404 likes this.
