Is it possible to get the aorus 15g's fans below 25% fan speed?
Discussion in 'Gigabyte and Aorus' started by hongkongphooey99, Apr 30, 2021.
  1. hongkongphooey99
    hongkongphooey99 Notebook Guru
    Been tweaking fans with deep control is it only possible to stay at 25% fan speed? Also any updates on Resize bar bioses out in the wild lol?
  2. seba84_2005
    seba84_2005 Notebook Consultant
    Try use azure ai when you browse internet or watching movies.
    With azure ai my fans goes stop:
    if necessary, fans turns on for cool cpu.
  3. Ramsey
    Ramsey Notebook Enthusiast
    Tell me about it! Same on my Aorus 17G YC.
    It's super annoying that we're not allowed to go below 25% unless we use Quiet. The laptop runs cool with normal/gaming fans so there's no need for that 25% fan always whining (it's high-pitched).
    This effectively makes us work harder daily, opening the buggy Control Center multiple times per day to switch between Quiet (which actually drastically reduces the performance of the CPU and laptop) and gaming/normal mode. Good luck when you open Control Center, it rarely goes to the front of the apps so you have to go to your desktop to see it. Gigabyte has bad coders and software.
    If only we could stick to using Deep control.
    But, if Azure AI works to keep it quiet, that could be a solution. I'll try it later and see.
  4. hongkongphooey99
    What settings do you use? ive been trying azure AI and ive never seen my fans go below 2000RPM which is 25%. Do the 15G and 15P share the same fans? @seba84_2005
  5. seba84_2005
    @hongkongphooey99 nope 15P have a little different cooling. It is 4mm thicker.
    15P
    15/17G
    dmanti likes this.
  6. David H
    David H Newbie
    dmanti likes this.
