Is it possible to cure the clicking noise by shaking it?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by 4fingers97, Mar 24, 2009.
  1. K-TRON
    K-TRON Hi, I'm Jimmy Diesel ^_^
    Shaking the drive is the best way to silence your drive, it completely kills it, therefore it makes no noise :p
    Seriously, do not shake your harddrive especially when it is on. If the system drive make noise, use software like hdtune pro, or hdparm to change the AAM settings for noise/performance
    K-TRON
  2. 4fingers97
    4fingers97 Notebook Evangelist
    Well how can I make sure that my HD is still ok and its not broken?
  3. Bog
    Bog Losing it...
  4. 4fingers97
    What this automatic acoustic management feature? I am scanning my hardrive right now
  5. namaiki
    namaiki "basically rocks" Super Moderator
    The heads should never touch the platters; the clicking is when the heads move off of and onto the parking ramps.
  6. 4fingers97
    it says everything is Ok but I am doing an error scan since the benchmark is done. Also if there are no errors does that mean my HD is not damaged? I looked at device manager and it says device working properly.
  7. namaiki
    If you shook it when it was turned off, then I do not think there would be any damage.
  8. 4fingers97
    yes it was off when I shook it. But I dont hear the clicking noise that much though. It kind of scares me
  9. Hep!
    Hep! sees beauty in everything
    Yeah, I don't think you have a problem with your drive. If you're REALLY scared you can run a test with the drive manufacturer's tools, but honestly, if you'd done damage it would already be painfully slow to use or maybe entirely unusable.
  10. 4fingers97
    Alright well my computer is still very very fast and it doesnt seem to have any problems.
