Is it normal for IPS displays to have edge backlight leak?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Quicklite, Jul 12, 2017.
  1. Quicklite
    Quicklite Notebook Deity
    Hi guys,
    Quick query. Do some image editing from time to time.
    Have been working with a few laptops lately (trying to find a unit that's decent), e.g. AW 17 R4, HP ZBook 14, 15, Asus GL502, GL753 - they're all IPS. These units - when you have a pitch black background all seem to have some extent / smaller backlit bleed/leakage next to the display edge / bezel, etc. On normal background, even darker grey - becomes much less visible.
    I suppose quality control / courier could impact these. Could I just ask if I'm being too picky, or is this a normal occurrence / something to do with the construction of IPS display that makes them more sensitive to developing backlight leak around the edges / bezels of the display? or have I just had really bad luck? (I've seen good units of these models more often than the leaky ones - though I suppose now I know what to look for / switch on black wallpaper - they're much more visible).
  2. don_svetlio
    Backlight bleed is quite common on modern-day laptops - it's not really too big of an issue in most cases.
  3. ChanceJackson
    ChanceJackson Notebook Evangelist
    Yup my 4K 3D LG TV has the corner bleed issue but its the only complaint about it I have and it seems to be a luck of the draw kind of thing to get an IPS without that symptom
