iPod touch wont connect to wireless router
Discussion in 'Networking and Wireless' started by xdz3r0, Mar 31, 2008.
  1. xdz3r0
    xdz3r0 Notebook Consultant
    so basically, i have an ipod touch. and i wanna use it for internet purposes as well as music, videos, ect. but it cant connect.
    my router, dir-655, is password protected, wpa, but when i type in the correct password on the ipod, it says that it is unable to join the router.
    so, is the problem with my router or my ipod? help appreciated. thanks.
  2. Sam
    Sam Notebook Virtuoso
    Does the router work with a notebook? If it does, then its probably not the router issue.
    My iPod Touch connected fine to my wireless network. Did you make sure to set to the right encryption setting? WEP, WPA...
  3. knightingmagic
    knightingmagic Notebook Deity
    Try removing quote marks from the WPA key.
  4. xdz3r0
    yeah, my laptop does connect to my router.
    the encryption thingy says 'WPA - Personal Only' or something similar (cant remember). i assume thats wpa, so thats what i picked. still doesnt connect.
    what quote marks?
  5. Patrick
    Patrick I beat spamers with stiks
    my touch works fine with my router as well
  6. qhn
    qhn Notebook User
  7. Modly
    Modly Warranty Voider
    Perhaps you've got WPA2 setup on the router?
  8. FredKS
    FredKS Newbie
    I have had precisely the same issues with the same router. I can access the network if the security setting is set to "none", but this is impracticle, of course. I then checked to see if I could acquire a friends network using his password and had no problem. I could also acquire the network at the local Apple store. I also had no problem accessing the network with my son's earlier version of Ipod touch, and 2 MacBooks.
    Changing the setting to WEP, as the Apple help desk suggested did not solve the issue. I spent over an hour on the phone with the help desk, without resolution. Apparently, Apple is working on this and I am to call back in about a couple of weeks. I am tempted to start over with another router.
    Please let me know if you have found a solution in the meantime
  9. SpeedyMods
    SpeedyMods Notebook Deity
    I also have issues with my father's iTouch. It will not connect to our DIR-615. Luckily, our ISP provides a DSL modem with a wireless router built in, but I would like to see if this can be fixed. Nothing else has issues with this router. It's the most reliable I've used. PSP, PS3, and 4 laptops connect fine.
    Greg
  10. ahl395
    ahl395 Ahlball
    I have a DIR-655 and my Touch connects fine. I belive it is set to WPA2 also.
    If you use N, make sure that the router isnt set to N Only.
    SOmetimes though, the touch has glitches. Try selecting Other in thw WiFi detection section, and then putting in all your network info and try to connect again. ALso reboot the ipod and router. Sometimes, you have to do a complete restore/wipe of the iPod too.
