IP Camera Software
Discussion in 'Windows OS and Software' started by ViciousXUSMC, Feb 18, 2015.
  1. ViciousXUSMC
    ViciousXUSMC Master Viking NBR Reviewer
    So I finally broke down and got some IP cameras.
    I found a deal I could not refuse on a cheap VGA quality DLINK Wireless IP Cam for $20 and after using it for a week or so really liked what it was doing for me but found that I would like to step up.
    So on order is a 720P Foscam with the pan/tilt and I think a wider angle lens
    But already I found a camera that I wish I had gotten for a bit more that has 1080P and a wide angle lens with some other great features.
    The short of the long is that with the dlink the dlink software was great for viewing/recording and the dlink app is also really great for remote viewing on my phone.
    As soon as I get the Foscam and later on what brand I get next I will not want to be running 3+ pieces of brand specific software and will need to use one of the many brand neutral suites.
    Currently I am using ISPY and it seems pretty good, but its not free anymore and they want a monthly fee to use the remote feature and some of the other benefits.
    Next I think I am going to try XProtect Go as they have a free version for up to 5 cameras (not sure if it has any other limitations)
    Do you guys into this stuff already have a good setup you recommend for the software? I would want to avoid monthly fees.
    Then there is the whole "what is the best way to view remote" debate. Something like the dlink app is great but I do already have a DDNS server I use for my mumble server, I can easily forward some ports and connect via URL if that is the best way. Also for a program like ispy where local viewing is free. I wonder if I might use a VPN so that I can connect remote and appear as a local connection.
    Its thoughts like that, that I would like to bounce around and see what others have tried and or recommend.
  2. TreeTops Ranch
    TreeTops Ranch Notebook Deity
    You want to broadcast from your camera to the world or to a specific person? If a specific person, I think yawcam software can do it. You would have to let that person know the URL. The trick is to use a static dns and it looks like you have a server so that should work. Don't know if VPN would work with yawcam software.
  3. ViciousXUSMC
    Not the world, while anybody with the url could connect I want it to require authentication at connection.
    Or if not via url just via an app that would be fine as well.
  4. TreeTops Ranch
    Then just use a service like UStream.tv Pretty sure you can use a password for authentication. Then give the password to those who you want to see the video.
  5. KLF
    My coworker got a foscam (can't remember what model tho) few weeks ago. Works with ddns and has phone/browser apps. He's happy with it and if I needed one I'd probably get the same thing.
