Internet Explorer opens in default "work Offline" -- how to change?
Discussion in 'Windows OS and Software' started by Justitia, Jun 2, 2008.
  1. Justitia
    Justitia Notebook Evangelist
    Everytime my friend clicks on IE, it always comes up with "work offline" checked. We aren't sure when it started.
    But I can't figure out how to change the settings so IE will open working online, as it normally does with everyon else.
    Can anybody help?
  2. Spyda Kat
    Spyda Kat Notebook Consultant
    When you change the setting in the options, it always revert back to work offline when you open it again?
  3. Justitia
    Yep!... That is exactly what happens. I have never seen anything like it before.
  4. Spyda Kat
    Try this:
    Look in the registry (START >> RUN >> REGEDIT)
    Using regedit, find the folder:
    HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\WebCheck
    And check that these two *String* keys are set to auto:
    "LoadSens"="auto"
    "LoadLCE"="auto"
    Create them if necessary!
    Source http://www.dslreports.com/faq/357
    Always backup your registry before editing :D
  5. Justitia
    This is a little above my skill level.. :p It also seems a little like overkill. Surely there's got to be someplace on IE where you can change certain defaults. I just can't seem to find it.
  6. Spyda Kat
    :) It's really not that hard if you have instructions. But I should tell you mess up your registry there's a possibility you could screw your computer. To access the registry editor press the windows key (flag) and "R", then type in regedit.exe You could do that or wait and see if someone else comes. I don't use IE that much. But I'll take this chance to recommend Firefox to you as it is much faster and secure and overall just better.
  7. Nocturnal310
    Nocturnal310 Notebook Virtuoso
    Dont confuse the lady guys.
    Hi Mam... do this:
    1. Open IE
    2. Go to Tools, click Internet Options.
    3. Click on Advanced Tab & there is 'Reset' Tab...Click on it and Reset all your IE settings.
    4. Restart the IE.
    5. Give me Rep.
    Do that and let me know if it works... if it doesnt i ll tell u alternate method.
  8. bigozone
    bigozone JellyRoll touring now
    open IE
    click on TOOLS
    click on INTERNET OPTIONS
    click on USE DEFAULT
    click APPLY
    click OK
    close window
    close IE
    restart IE
    keeps all other internet settings incase you had some customized
    bigO
  9. Justitia
    The only "use Default" I see is for setting the home page. Will that also set whether IE opens online or offline? Or is there another "use default" I am missing?
  10. Justitia
    Sorry -- missed your post in the last response. I am reinstalling IE at the moment. If that doesn't do it, I will try what you suggest.
