Internal Fan Upgrade
Discussion in 'Hardware Components and Aftermarket Upgrades' started by IceDragon7, Aug 26, 2007.
  1. IceDragon7
    IceDragon7 Notebook Evangelist
    Is this possible? To get a better internal cooling fan for your laptop?
  2. Agent CoolBlue
    Agent CoolBlue Notebook Deity NBR Reviewer
    Doubt it, you can probably get replacements though.
  3. IceDragon7
    So an external cooling fan is the only option?
  4. Agent CoolBlue
    I recommend a cooling pad like the Zalman NC-1000
  5. IceDragon7
    Well the point was to not have to carry a external cooling pad
  6. Greg
    Greg Notebook Nobel Laureate
    You won't really be able to do this.
  7. adinu
    adinu I pwn teh n00bs.
    These aren't desktops.
    The fan that it comes with is the one you're stuck with. You can get a replacement like lawlz said, but you can't buy an aftermarket one that's gonna cool better like you can on desktops.
  8. star882
    star882 Notebook Evangelist
    With a lot of work, you can probably find a more powerful fan that will fit.
    But in the last laptop I had to fix (an old 2.8GHz Prescott), just rewiring the fan directly to the supply (5v in my case) was enough to cool that Prescott.
  9. Agent CoolBlue
    Aren't Prescotts old Intel P4s?
  10. star882
    Yes they are. And they're hot, exactly what you don't want in a laptop.
