Interested in a CF-31 I found on ebay and asking for opinions
Discussion in 'Panasonic' started by tomandjerry, Oct 24, 2020.
  1. tomandjerry
    tomandjerry Newbie
    Hi everyone.
    Looking to buy my first Thoughbook (always owned Thinkpads before).
    PLEASE give me your opinions on this laptop I found on ebay:
    https://www.ebay.co.uk/itm/264867638010
    - Anything odd in the description? Does the laptop seem good?
    - Can I trust the BIOS that it only worked for "90 hours"?
    - Is it worth the amount of money seller asks?
  2. Geraout
    Geraout Notebook Consultant
    Is there any reason that you need a mk5? . If you're doing high performing tasks then you'd probably be looking at a cheaper standard laptop.
    To me the difference in performance between the mk3 mk4 and mk5 is negligible. A performance edition mk3 or mk4 can outperform a mk5 anyway. Mk5s are not available in performance spec.
    Toughbooks are so resilient that I would always go for condition and spec over a low number of hours. A unit with dedicated graphics, GPS or mobile broadband etc in great condition would be for me a better buy than a low hours standard spec model.
    The price of the unit you've linked to seems a little high compared to others listed. The price reflects the 32gb ram supplied as a CF31 can take only two sticks of RAM and 16gb sticks are about £100 each. (If you need 32gb of ram you need Mk5 + to support it). The listed unit has GPS and LTE.
    No reason to suspect the hours use is wrong. It can't be hacked and the unit condition looks right. The first three pictures look to be stock photos of a different unit.
    I'd advise against using the USB 3 PC card supplied as the current draw can harm the motherboard.
    tomandjerry likes this.
  3. tomandjerry
    tomandjerry Newbie
  4. tomandjerry
    tomandjerry Newbie
    Yes I'm a bit clueless if that's what you are wondering.
    However, I don't have a lot of free time to go into everything which is why I'm looking for an easier way to find the answers.
    I will need the laptop for running "heavy" software like for computational chemistry.
    I'm not sure if I want mk3 or 4 or 5 or whatever, I just been told that the greater the number the better the machine.
  5. Stewboy
    Stewboy Notebook Consultant
    Gearout, can you say something more about the use of usb 3? I've got a 31 mk4 and use the usb 3 slot fairly regularly. I don't mean to hijack the thread.
  6. Geraout
  7. Cognetic
    Cognetic Newbie
  8. tomandjerry
    tomandjerry Newbie
  9. Geraout
    That is a mk1.
    Mk1s have a slightly lower brightness screen (1100 vs 1200 lumens) than later models.
    1st gen i5 processor.
    WiFi is Intel® Centrino® Advanced-N 6200 vs 6235 on later models.
    No USB 3.0.
    Bluetooth v2.1 vs v4.0 on later models.
    They want an extra £58 if you want the DVD drive.
    I'd look for a mk3 +
  10. Stewboy
    Here's my advice. This looks to be a cf-31 mk1. I would look for a cf31 mk4 with Windows 10. Though I loved--and continue to love--Windows 7, Windows 10 with various fixes (all found on the Notebook Review Windows 10 forum) has worked very well for me, and I'm not an MS fan.
    For reference, I got a mk4 with 4k hours, 9 out 10 cosmetic condition, Windows 10 64 bit, for $375 US. I still use both of my cf30s with Windows 7, but the 31 mk4 with W10 is pure pleasure to use.
