Intel-TongFang QC7 (Element/Fusion 15/MAG-15/Vapor 15 Pro)
Discussion in 'Other Manufacturers' started by B0B, Sep 2, 2019.
  1. TheUberMedic
    TheUberMedic Notebook Evangelist
    Well Eluktronics is a US based company and XMG is a Germany based company so... It kinda depends on where you live. I personally have an XMG Pro 15 (early 2018) and I haven't had any issues with it.
    So get the one which is closest to you so you can get support readily available and not wait months incase something breaks.
    Also repasting is never a bad idea if you're using something like liquid metal. But from initial thoughts from Dave2D, I don't think it'll be needed :p
    XMG likes this.
  2. MidNerd
    MidNerd Newbie
    Does anyone know if the Thunderbolt 3 DP out is from the GPU or CPU? This looks like the perfect laptop for me, but it's a non-starter if I can't use a Valve Index with it.
  3. cvex24
    cvex24 Newbie
    Blacky and lo_Op like this.
  4. dumpsterj
    dumpsterj Notebook Guru
    I have a Rift S and I need displayport through that usb-c or its a nonstarter for me as well.
    LOL I literally got this response in email SECONDS after making my replys
    Hi Justin,
    Thanks for your message. Yes, displayport over USB-C is supported.
    Thank you!
    Eluktronics Sales Team"
    B0B likes this.
  5. Mr. Fox
    I looked at this newer Tongfang option versus the MECH-15G2Rx and ultimately elected to stick with the older system because of the dual mini-DP output it offered and the fact that the keyboard on the new one is missing the numeric keypad. Both of those features were more important to me than having TB3. My impression from Dave's video also suggested the keyboard backlighting was somewhat muted or softer on the newer model, and I prefer brighter backlighting. I prefer the muted black color and metal bottom panel of the newer model better, but I also prefer the more chiseled/angular look of the older chassis. The flat lid and blunt edges are a little bit lacking in character for my personal tastes. It seemed like Dave's impression was that the audio output quality was also inferior... perhaps due to the bottom cover hindering the audio output.
  6. wtferrell
    wtferrell Notebook Evangelist
    I made my order today, with the RTX 2070 MQ and Conductonaut paste, etc. I'll try to post some impressions when it gets here.
    Mr. Fox likes this.
  7. Shere Khaan
    Shere Khaan Notebook Enthusiast
    Can't wait to hear how it goes, good luck!
  8. TheUberMedic
    I wonder how it'll compare to the Clevo PB51 which is what I have. The Mag is a full cm thinner and has a larger battery but uses a MaxQ that can turbo like a MaxP.
  9. Prerana
    Prerana Notebook Enthusiast
    Very excited to get a bigger battery in my OP17. It has only 46whr which does not even do 3 hours as processor does not reach c7/c8 sleep states
    The dimensions look the same but I will wait for your confirmation before making the purchase
  10. B0B
    B0B B.O.A.T.
    This MAG-15 is stunning!
    lo_Op, Arondel, Prerana and 2 others like this.
