Intel-TongFang QC7 (Element/Fusion 15/MAG-15/Vapor 15 Pro)
Discussion in 'Other Manufacturers' started by B0B, Sep 2, 2019.
  1. faenil
    faenil Notebook Consultant
    I meant the negative charge rate (discharge ;))
    On the m15r1 I tested it was 7.5W to 8W, and package CState could not go below PC3
    I will get the numbers on my XMG Fusion 15 tonight, but I would like to get numbers from other users too, just to make sure they match.
  2. Shere Khaan
    Shere Khaan Notebook Enthusiast
    I think it is 50 degrees they kick in, I wasn't watching the guage for the cutoff, sorry. on the plus side the cooling system works well :D
  3. elgreco14
    elgreco14 Notebook Enthusiast
    I get same on my m15r1. Still good for 10 hours of use.
  4. XMG
    XMG Company Representative
    The fans ease in with 30% at 50C and shut off after 3 minutes below 48C.
    Different tools might read different temps though.
    Charge rate depends on the charge status (%) of the battery. I'm away from my sample for a few days and can't give you a reading right now.
    Cheers,
    XMG|Tom
  5. faenil
    We are talking about the power consumption as measured at the battery point, not an actual chargin rate.
    The AC needs to be disconnected. The Charge Rate will be a negative number that can be interpreted as the power consumption of the machine.
  6. sheard
    sheard Newbie
    Does anyone have news on Shipping status of eluktornics ?
    i ordered mine at eluktronics website on 18 th September , Never heard back from them . Writed 3-4 times to their email, but they never get back to me , I ordered mine with liquid metal paste .
  7. buffalofloyd
    buffalofloyd Guest
    Can the drivers from XMG be used if the laptop came from Eluktronics, and vice versa. Are they all universal?
  8. XMG
  9. faenil
    Drivers should be the same.
    I wouldn't risk it with the BIOS, just in case they have custom incompatible versions (although I doubt it).
  10. buffalofloyd
    buffalofloyd Guest
    Thank you very much for your help and prompt response!
    XMG likes this.
