Intel-TongFang QC7 (Element/Fusion 15/MAG-15/Vapor 15 Pro)
Discussion in 'Other Manufacturers' started by B0B, Sep 2, 2019.
  1. nibbtastic
    nibbtastic Newbie
    Btw, does anyone have any picks or videos of the repaste process for the QC71B (RTX 2070) model specifically? I seem to have misplaced a thermal pad and am now experiencing thermal related crashes. Just want to make sure I’m covered everywhere I should be.
    Cheers!
  2. Diegoweb
    Diegoweb Notebook Enthusiast
  3. Djerii
    Djerii Newbie
    Thanks!
    Actually found the same question in their discord and got it working! You need a .dll file and an other build to get it working on some qc7 laptops. It's flickering a bit. But I'll check with them in their discord if they have a fix.
  4. StormFalcon
    StormFalcon Notebook Consultant
    Anyone get dpc_watchdog_violation blue screens? Normally I would dial the undervolt back a bit but google tells me this one is related to SSD drivers.
  5. Diegoweb
    I had this error with my Desktop. It was not related to SSD whatsoever.... For some reason Windows Update got a new driver for my Intel Ethernet adapter and something was broken with that update. I just had to go to Device Manager and rollback to a previous driver.
    But in short this error is usually something related to drivers, not necessary SSD or ethernet adapter.
    I suggest you to download WhoCrashed and run it. It will read all dumps from windows folder and get you an idea what is happening.
    Just make sure when you get a BSOD you let Windows finish the diagnosis and reboot itself, otherwise you may not get the dump file and you will be unable to understand what is happening.
  6. StormFalcon
    Thank you, I will install that and see what's up. I filed a support ticket to eluktronics so hopefully they can give me some pointers.
  7. StormFalcon
    Well turns out the issue was related to my soundblasterx g5 drivers and is a relatively common issue, which is a bit unfortunate.
  8. mikaris
    mikaris Newbie
    Hi everyone,
    Aftershock vapor 15 user here
    Anyone having trouble having the laptop supply power to the left USB port in S4/S5?
    It's plugged into the power adapter and hasn't been set to any battery saving modes...
    I can't find any option in the bios, to my knowledge it should supply power even when off given it has the battery symbol next to the port?
    Many thanks
    Mika
  9. Sandman1402
    Sandman1402 Newbie
    Hi everyone,
    I just have an idea with using Hyperjuice usb-c charger with PD 100W-20V/5A to charge the Mag-15. I saw on Tom reply on Reddit about
    90W Universal Adapter can charge the laptop while in Power saver/ Balanced mode. Is it poossible?
    I am trying to find an usb-c to barrel connector (5.5 x 2.5 x 12.5) but still no hope for the thing.
    Thanks,
  10. Diegoweb
    WoW, that's actually a pretty good idea. I've seen some people converting barrel plugs to usb type c, but never come to my mind to use in a laptop.
    5.5mm x 2.5mm seems to be pretty easy to find. Only the length is hard to find since most product pages never mention the actual plug length.
    Aren't they supposed to be in a standard 12.5mm?
    In AliExpress I found this adaptor:
    https://www.aliexpress.com/item/33034965138.html
    While in Amazon US:
    https://www.amazon.com/Female-Rectangle-Charge-Laptop-5-52-5mm/dp/B08331ZNTP/ref=sr_1_5
