Intel-TongFang QC7 (Element/Fusion 15/MAG-15/Vapor 15 Pro)
Discussion in 'Other Manufacturers' started by B0B, Sep 2, 2019.
  1. elgreco14
    elgreco14 Notebook Consultant
    Lol, they could have just made the QC7 without these dumb cutouts. They did on the: GK5CP7Y which is the same build, but better.
  2. elgreco14
    Found a seller for the QC7 battery: https://www.aliexpress.com/i/4000242217969.html
    The TongFang QK5CP7Y looks to have almost exact layout as QC7.
    Perhaps you could buy this with the 240hz or oled and then buy this battery. Then you got better display, better chassis without those ugly cutouts and 2060/2070 max-p :) However it is not a mechanical keyboard looking at specs.
  3. FourJun
    FourJun Newbie
    new control center looks like no problem for now.. (mayb still need some day of using then will know)
  4. genexis_x
    genexis_x Notebook Consultant
    All GK5s have similar internal layout
    QC7 battery wouldn't fit in GK5 chassis, probably including GK5-Y
  5. FourJun
    FourJun Newbie
    elgreco14 likes this.
  6. Underson
    Underson Notebook Enthusiast
    are you sure? how come its available on newegg , telling it in stock and alows me to make an order?
  7. CreatureCore
    CreatureCore Notebook Guru
    They actually might have some, Amazon says there is 14 units in stock. But give them an email to be sure.
  8. elgreco14
    The form of battery looks exactly the same. However the other one has more capacity.
  9. gman29
    gman29 Notebook Guru
    Does the installation sequence matter? I ask because before updating to the 2.1.0.19 version of the Control Center, I already had 26.20.100.7463 installed.
    I'm noticing that the performance under the Quiet and Balanced profiles seem to be a bit underwhelming, especially when unplugged. It feels a bit "skippy" if that makes sense. Not quite like the freezing problem before, but just a bit jumpy/laggy.
  10. buffalofloyd
    buffalofloyd Notebook Enthusiast
    I notice this as well,especially when watching a YouTube video. There's definite skipping or stuttering from time to time, it might even occur on Enthusiast mode, or whatever it's called, I can't remember.
    gman29 likes this.
