Intel-TongFang QC7 (Element/Fusion 15/MAG-15/Vapor 15 Pro)
Discussion in 'Other Manufacturers' started by B0B, Sep 2, 2019.
  1. eddi3x3x3
    eddi3x3x3 Notebook Evangelist
    What did you have to tweak for dark souls 3? Interested since I do want to start playing that game soon
    Sent from my Moto Z (2) using Tapatalk
  2. FourJun
    FourJun Newbie
    having same problem here and the blue screen error is critical process died. and i notice that it will happen when i open google chrome and AFK too long in power saving mode with power plug-in
    -Level51 by aftershock vapor15 pro
    -ssd using corsair mp510 960gb
    btw after install xmg cc version 0.19 my battery consumption still 20w-30w (from hwinfo) but after i open intel graphic cc it back to normal ..
  3. Underson
    Underson Notebook Enthusiast
    Ok still want to order it to russia, unfortunately XMG representative told me that they need to assemble an item before i can buy it and it will be no earlier than start of Jan which is sad so i'm still thinking of ordering Mag.
    I found it for $1499 on newegg site (it telling that Reseller is Eluktronics): https://www.newegg.com/matte-black-...mag_15_eluktronics-_-9SIA8S1A153169-_-Product
    Guys, while im not from US, can you recommend this?
    Do you think i should pay for extra service on proxy mail to check it for broken pixels and overall working?
  4. gman29
    gman29 Notebook Guru
    Power management mode - Prefer maximum performance
    Threaded optimization - On
    Triple Buffering - On
    (Source: https://steamcommunity.com/app/374320/discussions/0/365163686080707830/)
    And then in-game, I turned off Depth of Field and Motion Blur. All other settings are at High/Max. Game looks beautiful at a constant 60 fps.
    I also did tweaks to Nioh 'coz that game was unplayable before the tweaks. Now also a beautiful game at a constant 60 fps, but there were significantly more tweaks to be made. (Source: https://steamcommunity.com/sharedfiles/filedetails/?id=1195069538)
    I wasn't AFK at the time that it happened, but I was in and out of AFK. If I remember correctly, I was on Quiet profile, unplugged (not 100% on this).
  5. FourJun
    FourJun Newbie
    it happen to me 4-5times in quiet profile while using chrome . so now i normally use balance profile to avoid this happen
  6. gman29
    Do you still have this problem even after updating to the new Control Center? The problem happened to me BEFORE updating to the new Control Center, and it only happened to me just that one time.
  7. CreatureCore
    CreatureCore Notebook Guru
    If you order from eluktronics you still have to wait as they are also sold out. The time you have to wait is something you have to ask them.
  8. Randomisity
    Randomisity Notebook Guru
    Hey does anyone know how much power the USB-C port can put out?
    If the battery on the QC7 is basically the max allowed by the FAA, then the 17" version is going to have worse battery life because the battery size can't increase but there's now a bigger display it has to drive?
  9. elgreco14
    elgreco14 Notebook Consultant
    Install memtest on usb and then boot from it: https://www.memtest86.com/
    Run some tests and check if your ram is ok. Bad ram can cause system instability.
    Check your ssd for bad blocks with https://www.hdsentinel.com/download.php
    Randomisity likes this.
  10. elgreco14
    I don't think it works like that, maybe be power draw is slightly more because there maybe are more LEDs. But should be negligible.
