INTEL-SA-00086 Intel Management Engine Critical Firmware Update
Discussion in 'Razer' started by Vistar Shook, Jan 7, 2018.
  1. Vistar Shook
    Vistar Shook Notebook Deity
    As with every firmware flashing, do it at your own risk.
    Close all open programs, including AV, and make sure laptop is plugged in and charged.
    Note: This only affects the Blade models listed below. There is no action needed if you model number is not one that is listed below.
    Model Number Model Name
    RZ09-01682 Razer Blade Stealth 12.5” (2016) - Intel 6500U
    RZ09-01962 Razer Blade Stealth 12.5” (2016) - Intel 7500U
    RZ09-01963 Razer Blade Stealth 13” (2017) - Intel 7500U
    RZ09-01964 Razer Blade Stealth 13” (2017) - Intel 7500U
    RZ09-02394 Razer Blade Stealth 13” (2017) Intel 8550U
    RZ09-02393 Razer Blade Stealth 13” (2017) Intel 8550U
    RZ09-01652 Razer Blade 14” (2016) - GTX970M
    RZ09-01952 Razer Blade 14” (2016) - Intel 6700HQ - GTX1060
    RZ09-01953 Razer Blade 14” (2017) - Intel 7700HQ - GTX1060
    RZ09-01662 Razer Blade Pro 17” (2016)
    RZ09-01663 Razer Blade Pro 17” (2017)
    RZ09-02202 Razer Blade Pro 17” 2017 - GTX 1060
    If you model is listed above please follow the steps below to update your Razer Blade
    Please save all your work and close all open applications as your Blade will automatically restart following this update.
    Download the file from http://razerdrivers.s3.amazonaws.com/drivers/RazerUpdater_v1.0.6.2_ME-11.8.50.3425.exe.7z
    Click on the file to open the application
    If the system does not need to be updated it will display the image below and you can close the application knowing your Blade is up to date.
    If your system needs the update the image below will be displayed.
    Click the “UPDATE” icon to begin the update.
    The system will automatically apply the update and will reboot on its own when the update is completed.
    To ensure that the update is installed, click on the same application again and it will display the confirmation below.
    End
    Do tell us if you have encountered any other issues related to the Intel Firmware Vulnerability.
    Papusan, Assembler, Nuke33 and 2 others like this.
  2. Nuke33
    Nuke33 Notebook Consultant
    Thanks ;)
    Vasudev and Vistar Shook like this.
  3. Assembler
    Assembler Notebook Consultant
    Razer announced today, that they plan releasing another update to address the Spectre vulnerability (CPU microcode update). If they deliver, we might have a 3in1 update for:
    1. The Intel HT bug
    2. Intel ME vulnerability
    3. Spectre
    Vasudev, Nuke33 and Vistar Shook like this.
  4. Vasudev
    Maybe 2 in 1 because the new spectre microcode already has built in fixes for HT bug.
    As for MEI FW you can grab it from Win-raid and use Intel CSME System tools repo.
    Vistar Shook likes this.
  5. Vistar Shook
    The MEI firmware update is the one from this thread....link on the first post.
    Vasudev likes this.
  6. Vasudev
    I thought Assembler was using a Razer from Late 2015 which didn't get MEFW.
  7. Vistar Shook
    Oh...I see. This particular vulnerability affects 6th, 7th and 8th gen intel core processors. Haswell is not affected, so now we are waiting for the spectre patch to be released.
    Enviado de meu Pixel 2 usando Tapatalk
    Vasudev likes this.
