Intel P9500, SP9600
Discussion in 'Lenovo' started by furrycute, Aug 24, 2009.
  1. furrycute
    furrycute Notebook Evangelist
    What's the difference between these 2 processors? They both seem to have the same clock speed, the same amount of L2 cache.
  2. Micaiah
    Micaiah Notebook Deity
    SP9600 has a smaller die (22mm squared) and uses a ball grid array interface.
  3. furrycute
    Thanks. Which one is the better processor? I notice the T400s uses the SP9600, but the regular T400 uses only either the P or the T processor.
  4. sgogeta4
    sgogeta4 Notebook Nobel Laureate
    The main differences are the physical size, the SP9600 being smaller and is soldered into the motherboard, so you can never upgrade it w/o replacing the entire motherboard. The P9500 is a socketed and can be replaced relatively easily, but will probably void the warranty. The underlying design is identical.
  5. furrycute
    Thanks! That's good to know.
  6. twister
    twister Notebook Evangelist
    I thought SP had lower power, 25W? If so, than it generates less heat and results in battery life improvement. Also, in case of T400s, BGA package is the only way to go to make it thinner by eliminating height of the socket.
  7. gforce23
    gforce23 Notebook Enthusiast
    The P8xxx and P9xxx processors have a TDP of 25W as well. In fact, the P9xxx are the best mobile processors at the moment since they provide all the power and cache of the T9xxx while dissipating only 25W.
