Intel Optimus Display Overclocking
Discussion in 'Alienware 18 and M18x' started by ssj92, Oct 6, 2018.
  1. ssj92
    ssj92 Neutron Star
    Well, since third gen (Ivy bridge) graphics don't support the official intel solution to overclocking and I can't use PEG mode (Optimus only). I went ahead and had my friend help me flash my EDID in Linux. My laptop now has 85hz available everywhere.
    I used CRU to add the resolutions, then exported the EDID and flashed it in Linux using edid-rw. My friend is lazy and won't make a tutorial sorry.
    basic steps:
    Open CRU in windows, add the resolutions/refresh rates desired (I started with 75, 80, 85, and tested each).
    Export EDID from CRU
    Launch Linux and use the edid-rw tool to flash the new EDID (use the help command to check what the command is to flash).
    Reboot and hope it didn't brick. TO be fair we flashed my EDID like four-five times and it's fine. Now I can run 75, 80, 85hz in games too. So smooth.
  2. Grant B Gibson
    Grant B Gibson Notebook Deity
    But can't you use CRU to set a custom HZ anyways, or no because of the iGPU? And isn't it available for Linux? Oh well this is a nice guide anyways
  3. ssj92
    ssj92 Neutron Star
    CRU only supports Intel 4th gen(Haswell) and newer. The drivers for 3rd gen(Ivy bridge) and older don't support any mods done by CRU or INF mods. So a flash is required to get around that.
    Grant B Gibson likes this.
  4. Grant B Gibson
    Also this is nice because the panel is natively at 85hz now
  5. ssj92
    ssj92 Neutron Star
    Yup! no issues in any game selecting the resolution/refresh rate! It is risky though if you do something wrong, you'll have a bricked display lol
  6. Rengsey R. H. Jr.
    I want to get this on my M18X R2
  7. ssj92
    ssj92 Neutron Star
    Don't you have PEG available on your M18x? Which GPUs is it running?
    I've been looking at M17xR4s actually recently lol
  8. Rengsey R. H. Jr.
    No edp on m18x.
    I can sell you my R4 with 120hz 3D panel.
  9. ssj92
    ssj92 Neutron Star
    I meant what GPU(s) are you running right now? This mod is only useful if you have 1060/1070/1080 installed that requires Optimus.
    Did you give up on the M17x? lol
  10. Rengsey R. H. Jr.
    Can’t you still overclock the panel if I run a WX 7100?
    Well , I have 2 AW 17 R1 and a M17x R4 , I really love the m18x though lol ... I need to get rid of them again....
