Intel Mobile Processor Compatibility Guide
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Commander Wolf, Jan 17, 2008.
  1. ninja564
    ninja564 Newbie
    the laptop is a Toshiba Satellite P205 S8811
  2. Commander Wolf
    Commander Wolf can i haz broadwell? Super Moderator
    I think you have a 965-Series chipset, in which case you won't be able to use a T9900. T9500 will be the best you can do.
  3. PapaSmurf69
    PapaSmurf69 Notebook Consultant
    According to the detailed specs it's a Mobile Intel® GM965 Express Chipset.
  4. thisideup
    thisideup Newbie
    Hello, I guess this is the right topic for this.
    I'm planning to upgrade my cpu and I could use some knowledge and guidance.
    The laptop in question is Toshiba Equium A200-1V0
    Here's the specs
    Toshiba
    it has T2310 cpu and the new one would T7500
    Here's the specs
    T2310
    T7500
    Now the questions. T2310 runs at 533 fsb and t75 at 800,
    chipset should be GM965 Express (not 100% sure)
    so, does that fsb matter, the motherboard should support 800,
    and as far as I know, I dont have to do anything to this?
    Other thing that I worry, is the voltage.
    t2310 has 1.2125 which is higher than t75 1.075 - 1.175
    Should I do something about this?
    and last but not least, the bios. I'm wondering if it will work?
    I know that the a200 model has been released with a c2d, but a lot lighter one, T5450 which is almost the same as t75
    Please let me know everything else that I should know before I buy the cpu and put it inplace.
  5. Commander Wolf
    If you've got a 965, the T7500 shouldn't an issue. If you want to be safe, T5450 is probably a better bet, but I don't really see any reason for the T7500 not to work.
  6. Marecki_clf
    Marecki_clf Homo laptopicus
  7. thisideup
    thisideup Newbie
    Yeh, I agree with you, that I would be safer with the T5450, but i'm tryin to get a sweet deal for that t75.
    Can you tell me anything about the volts?
    Any knowledge about that?
    Btw, really nice topic commander!
    yep, I did read that aswell :p
    hmm... do I have to change my ram from 667mhz to 800mhz?
    or will it work with the new cpu just fine?
  8. moral hazard
    your ram is fine, in fact if you buy 800mhz ram it will run at 667mhz with this chipset.
  9. redkachina
    redkachina Newbie
    Hello all, I've been reading this thread for quite sometime and decided to upgrade my Toshiba Equium A200-1V0 (T2310 1.4Ghz, 2GB DDR2 533Mhz, 120GB Toshiba HDD).. I got a replacement T7500 for quite cheap and luckily it booted:D I also add a 2GB module-3GB total and replace the HDD with OCZ Solid 2 60GB..the laptop just doesn't feel the same..
    Thank you CommanderWolf for creating the guide-otherwise I'd still be scratching my head for a compatible CPU lol..
    so Toshiba A200-1V0 bios ver. 2.5--->T7500 upgrade success;)
    Thisideup, I think you can proceed for T7500 too:p as we have the same lappy.
  10. thisideup
    thisideup Newbie
    excellent, thank you for the info!
