Intel Graphics Dimming problem
Discussion in 'Alienware M11x' started by Xzile609, Jun 17, 2010.
  1. Xzile609
    Xzile609 Notebook Enthusiast
    For some reason when im using my Intel Graphics mode I cannot dim the screen the OSD box pops up but no bars move when pressing FN F4 or F5.
    Works fine on the Nvida Mode
  2. Luminair
    Luminair Notebook Consultant
    I also experience this. Reboot the system - I assume this happens to you after closing the lid to suspend the system.
  3. Xzile609
    I wish it was that easy rebooting does not help and its like this all the time closing or opening the lid doesn't matter.
  4. CZroe
    CZroe Notebook Evangelist
    It happens to me too. Often, it dimmed and restored a few times already and after the next dimming it refuses to respond to the brightness controls. Even when it does respond, it isn't supposed to require me to adjust it again to turn it back up... it should "snap" to it based on what it was before it detected inactivity.
  5. erawneila
    erawneila Company Representative
    Can you guys tell me what version of the BIOS and OSD you are running? Make sure you have the most recent updates. I can't reproduce this on my M11x here at Alienware.
    Thanks!
  6. Xzile609
    Im running OSD 0.0.0.15C,A03
    BIOS A04
  7. RichP74
    RichP74 Notebook Guru
    I have this issue too. I go into the Power Options in the control panel, and I have to bump the brightness. It will randomly just go down to either very little or nothing. I've had the laptop for a week, and I've had to re-adjust the brightness slider (it affects the "battery" setting only) about 6 times. It just refuses to save the brightness setting for some reason.
  8. erawneila
    Oh, and which version of the video driver as well please?
  9. Xzile609
    8.16.11.8855
  10. Xzile609
    I found the problem finally
    While the Intel Graphics mode is enabled
    go to the device manager
    go to the Monitors section expand that
    make sure all you have there is the Generic PNP monitor uninstall any others if they are there make sure its enabled.
    Problem solved
