Intel GL960 chipset ... 4GB of "low-density" DDR2?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by MkFly, Aug 19, 2009.
  1. MkFly
    MkFly Notebook Consultant
    I have an Acer Aspire 4720Z, which sports an Intel GL960 chipset. I currently have 3GB of memory in it. I want to use 4GB. According to this (page 18):
    http://www.intel.com/Assets/PDF/specupdate/316274.pdf
    I may be able to use 256Mx64 memory to use 4GB. I'm not sure what this means exactly or how to determine it. I originally bought a 2x2GB kit for this laptop, and am using 1 of the 2 sticks:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231135
    Is that ^ high density, low density? How can I tell?
    Also, does that 256Mx64 mean per-stick, or per-SIDE? How do I get that in per-CHIP?
    Thanks ...
  2. jackluo923
    jackluo923 Notebook Virtuoso
    Usually on the memory chip itself, it'll say "25664"
  3. chaoticboi
    chaoticboi Newbie
    try 3gb of ram..
    slot 1: 1 x 1gb
    slot 2: 1 x 2gb
    works like a charm on my rig..
