Installing XP on a Vista System
Discussion in 'Windows OS and Software' started by Sp4rt4n, Jun 13, 2007.
  1. Sp4rt4n
    Sp4rt4n Notebook Enthusiast
    I have an Asus F3JP laptop, and id like to install XP on it. It currently has Vista. When I put the XP CD in and restart, nothing out of the ordinary happens, no options, no nothing...
    How do i install it?
  2. ttupa
    ttupa Tech Elitist NBR Reviewer
    You may have your computer's BIOS set to boot directly to the hard drive. What happens when you put your Vista disc in (or if you have a recovery disc and you try that)? You may have to tell the computer to boot to CD first. Then you will need to create a new partition for XP. I can't recall if there is an order to installing XP and Vista for dual boot, but you may run into that situation. Windows does NOT like downgrading (even when you're just trying to run in parallel).
  3. chimpanzee
    chimpanzee Notebook Virtuoso
    at the very least, you should see the boot up screen of the XP installation which is all text based.
    if not, check your boot option or else your CD is bad.
  4. PhoenixFx
    PhoenixFx Notebook Virtuoso
    Yes, change the boot order in the BIOS to have the CD ROM at the top.
    If you are planning to use both XP and Vista then after installing XP you will have to repair the MBR (master boot record) to have Vista boot loader in order to boot Vista.
  5. Sp4rt4n
    Alrighty... now how do i access the bios on a F3JP... iave tryed delete and f8 so far
    EDIT:
    Got it, changed priority... booted from CD rom, and it only asks me what OS i wanna boot. Vista is the only option, and theres no other options
  6. MB W163
    MB W163 Notebook Consultant
  7. Sp4rt4n
    I dont plan on dual booting, im going to install XP over Vista.
    And i found out my previous problem :)
  8. xavior
    xavior Newbie
    youll need to get a boot disk and disable the vista partition then you need a bootable copy of xp i did it how ever i cant seem to get all my drivers to work so just be warned
  9. mahmood
    mahmood Notebook Geek
    recently I have installed xp on vista home premium with out any problem. I booted from XP cd and delete vista partition (because there was only one C partition and it is assigned to vista) and create some new partitions.
    there is no problem.
    Do you get error message?
  10. Lawrence
    Lawrence Notebook Evangelist
    its easy...first make a partition. Here's a complete tutorial. then boot your laptop/PC and put your windows XP disc (Service pack 2), NOTE you should set first your boot options to CD in BIOS.then install it!
