Installing w10 get stuck
Discussion in 'Windows OS and Software' started by opayaa, Jul 22, 2019.
  1. opayaa
    opayaa Notebook Enthusiast
    Hello,
    I have an old laptop with windows7 installed, asus k53sc-sx441v, and everytime I try to install w10 it gets stuck on windows logo, right after the boot. I tried 2 different pen drive and re-installed MediaCreationTool multiple times. Coudnl't find anything on google aswell.
    I would appreciate any help.
    Thanks
  2. Vasudev
    Try older W10 builds such as v1809. The latest W10 may have some upgrade blocks on nvidia optimus laptops. Most v1903 features such as Game bar, Retpoline are backported to older LTSC version 1809 aka 17763.1.
    opayaa likes this.
  3. Rodster
    Rodster Merica
    That would be my suggestion as well. I remember on certain older laptops that I had, Build 1703 would hang after the final reboot. I used an older copy of W10 at the time and it installed and I was able to later upgrade it to the current build at that time.
    opayaa and Vasudev like this.
  4. Vasudev
    I have tried v1903 by clean installing 7 times a month and finally I lost it and installed v1809 with all latest updates integrated. It worked like a charm!
    opayaa likes this.
  5. opayaa
    Thank you guys, I'll try that but idk how to get older windows versions.. can you tell me where I download?
  6. Vasudev
    https://tb.rg-adguard.net/public.php
    Check the above link.
    opayaa likes this.
  7. opayaa
  8. opayaa
    Unfortunately it still gets stuck at windows logo, I tried 1809, 1803, 1709 and 1703. Windows 7 is not available for download on this website, can you link me another one for w7 home sp1 pls? Sorry but I can't download it from Microsoft and all I can find are shady websites. Also if you have another suggestions..
  9. Rodster
    Rodster Merica
    Are you installing from a USB Flash drive or a DVD? If a DVD you could try it from a USB Flash Drive or vice versa. How about posting the specs of your laptop i.e. CPU, amount of memory, video card, disk drive? If you don't know, you can use CPUz once you boot into Windows 7 https://www.cpuid.com/softwares/cpu-z.html
  10. opayaa
    I posted latptop model and also said I tried 2 different pen drives, I didn't tried DVD, don't have any atm.
    Here are the specs
    i5-2430M Dual Core
    GeForce GT 520MX / Intel HD Graphics 3000
    1x 4GB 1333 MHz
    HDD 500gb 5400 rpm
    I downloaded w7, will try to install later.
