installing internal bluetooth module on gateway t series
Discussion in 'Gateway and eMachines' started by dewsphere, Nov 27, 2007.
  1. dewsphere
    dewsphere Notebook Enthusiast
    i want to install a bluetooth module on a t-1620 but gateway doesnt seem to be selling the modules. does anyone know where to get one?
  2. qhn
    qhn Notebook User
    found one by urself yet?
    cheers ...
  3. dewsphere
    nope ive asked gateway and they told me i dont have an extra mini pcie slot when i do so no more trusting them
  4. lokster
    lokster Notebook Deity
    i think you do. onions review shows that there is indeed an extra mini pci slot for the laptop ive tried looking but the ones ive found include the wifi. :p
  5. dewsphere
    what did u find? bluetooth and wifi on the same slot?
  6. reasonabledave
    reasonabledave Notebook Enthusiast
    If you go to the Gateway Notebook homepage you will see the m-150 series which is essentialy the same as the T-1616 (intel though) In any case, then navigate to the support section for that model (M-150) and look up components, bluetooth module:Wa-La! we have various part numbers for what appear to be the same blutooth internal chip (foxconn) If you contact tech support, to try and purchase, they will send you to sales up-grade, the challenge is getting a rep that is able to comprehend what you are trying to buy! anyway after three tries I got a quote of 94 dollars GEEZ!
    Soooooooo I did not order it. If you look carefully at the picture on the "main view" page you will see that it is NOT minipci express. Go to the Dell website and look up "bluetooth module" easy to find, it looks to be the same part for $19.99 ! I have not done this yet, I believe there is a connector on the motherboard that accepts this module, the Dell website has instructions for their various models, but I have yet to Dissect my laptop, I have the P-6301 which is the 17" complement to the T-1616.
  7. lokster
    wow good job reasonabledave. tell me if you do find it. and pls show a link lol sounds like alot of navigating
  8. dewsphere
  9. lokster
    awesome would that work on the t-1616? ey onion if u read this can u tell us?
  10. lokster
