Inspiron 9300 Powers up but won't Charge
Discussion in 'Dell' started by Calabrius, Dec 29, 2006.
  1. Calabrius
    Calabrius Newbie
    Hi All,
    Has Anyone had this problem with there Inspiron 9300?
    My system works fine when running from the Ac adapter but it doesn't charge the battery ( the battery is new from dell under the recall) i have replaced the jack socket on the motherboard myself but still no luck.
    wasn't sure if to buy a new battery or get a new Ac adapter next ????:confused:
    Anyone got any ideas plz ..... also to add in Bios say ac adapter as unknow device also cannot detect the battery :confused: :confused:
    Thanks Guys and Gals
  2. Zero
    Zero The Random Guy
    Try and clean the contects on the battery and the notebook contects aswell. If your notebook is under warranty, then it may be a good idea to get Dell to repair it. Hope this helps.
  3. Calabrius
    Calabrius Newbie
    Thanks for the reply,
    I have tried the contacts and still no good :mad:
    Unfortunatly its just out of warranty,also with me installing a new Ac jack plug onto the motherboard wont go down too well with there warranty.
    Oh well its still with the AC adapter for now ... just ordered a new adapter tonight so we will see if that cures it..
    Cheers
  4. kegobeer
    kegobeer 1 hr late but moving fast
    It's probably the battery, especially if you didn't have this problem before you got the new battery.
  5. Calabrius
    Calabrius Newbie
    Thanks for the Reply
    I am just waiting for the Ac Adapter to arrive then if no luck with that then its the battery next.
    Calabrius
