Inspiron 1525 successful overclock
Discussion in 'Dell' started by User Retired 2, Sep 28, 2009.
  1. moral hazard
    I might add one thing, to do this mod you wouldn't really need to cut anything IMO.
    As long as you connect the TME pin to GND with a resistor it should work fine.
    If it doesn't disable TME, maybe use a 2k resistor or something smaller.
    Safer than cutting pins/tracks (I think).
  2. aces2195
    aces2195 Newbie
    Thanks again moral hazard for your advise. I will try your way and if it doesn't work i'll try a 2k or 5k resistor. How do i know if it doesn't work or not? What size of wire do i need to do this PLL pinmod ?
  3. aces2195
    aces2195 Newbie
  4. moral hazard
  5. aces2195
    aces2195 Newbie
    okay, let me keep on looking for the PLL and report back. From the look in the picture, it look like the same chip that i have but it has the different number on it. i tried to look around cpu and the ram area but no luck so far.Any hint on finding this chip's location?
  6. moral hazard
  7. aces2195
    aces2195 Newbie
    Hi moral hazard,
    sorry it took so long to respond. I had problems with my dell 1525, tried to take the laptop apart and it seem like my key board connection pins were damaged and i just got it back to working condition again and wrapped it up and not to tried to look for my PLL chip for now. i didn't want the key board to stop working from trying to look for the PLL chip. Maybe if i know exactly where to look for it , then it is ok to proceed with the mod. Thank you for your help.
  8. aduy
    aduy Keeping it cool since 93'
    hmm overclocking a dell?
    i wonder if this would work on my old d820.
  9. EtrustMe
    EtrustMe Newbie
  10. DanAlvarez123
    DanAlvarez123 Newbie
    I have a Dell inspiron 1520, with mobile intel 965 express chipset, CPU: Intel T7250 2.0 GHz and 1 GB (2*512MB) RAM.
    I am wondering if this mod will work on my 1520 :)
Similar Threads - Inspiron 1525 successful
  1. summersun
    1,037
