Inspiron 1520, win7 64bit bluetooth driver not working!
Discussion in 'Windows OS and Software' started by DanVan, Sep 7, 2011.
  1. DanVan
    DanVan Notebook Geek
    I searched for about 2 hours last night trying to get my bluetooth to work but it just would not work! Some info
    -My bios is up to date (A09)
    -Blue bluetooth light on the right is not lighting up
    -fn + f2 does nothing, and hitting the radio switch on the left also does nothing
    -tried the infamous R159805.EXE but the file just opened and closed and did nothing
    -Also tried the following files; R140135 , DELL_WIRELESS-370-BLUETOOTH-_A02-1_R235898.exe , Bluetooth_Broadcom_V7a_6.2.1.500.zip
    Does anyone have any advice?
  2. reb1
    reb1 Notebook Evangelist
  3. DanVan
    My computer came with vista 32 bit but I made sure it supported 64bit and got the upgrade
    ill try this method, thank you
    This is the program that just instantly closes when i run it, program R159805
    EDIT
    Ran it from cmd and it says "No capable devices found" which is untrue, i searched google for r159805 and no capable devices found and there doesnt seem to be an answer
  4. reb1
    I believe they want you to run that program prior to installing any bluetooth software. Because it was designed for changing to a different Vista or XP you should also attempt compatibility mode with it.
  5. reb1
  6. DanVan
    Im 90% sure I uninstalled the bluetooth software that was on my computer prior
    I alos made sure bluetooth was enabled in my bios
    I tried both xp and vista compability mode with all of the programs :(
    I cant believe ive run into an unsolvable problem!
  7. DanVan
    Already have this downloaded but only once (everything else has like 10x by it because I was trying anything.) so Ill be sure to try this again thanks
    Nevermind this is the one with both win32 and win64 in it, neither worked :(
    Ok new gameplan
    going to shutdown disable bios and try R159805
    Didnt work, even tried enabling the left radio switch to control bluetooth only
    i guess this is literally unsolvable
  8. reb1
    I put the Widcomm stack from my XP Pro on my 7 Pro and it allows me to use my bluetooth stereo headsets. To keep it there I had to rename the bluetooth inf file in Windows. I also had to hide an update for my bluetooth device that kept coming up in Windows update. Could this be causing some of your problems.
  9. DanVan
    Sorry a little confused on what to do / how to do this?
  10. PatchySan
    PatchySan Om Noms Kit Kat
    It's a long shot but how about this app which installs a generic Bluetooth driver for most BT adaptors?
