Incorrect voltage feeding LCD inverter - Cable or Motherboard?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by ditchmagnet, Mar 3, 2012.
  1. ditchmagnet
    ditchmagnet Notebook Consultant
    Wasn't sure if I should just put this in the general Hardware Components section.
    I have an Acer Extensa 4610Z that had a bad LCD screen (there were line running across the screen that would come and go as you pressed on the screen).
    I ordered a new screen and put it in, but the back light would not come on. Using a flashlight I could see that there were no longer any lines on the screen.
    I tried plugging in the old screen and the back light on that one would not turn on either.
    At this point I just figured the inverter was bad so I ordered a new one, but the new one was not making them work either.
    I didn't think I damaged the LCD cable when I was changing the screen, and it looks like all the little wires are intact in in the correct place on the connectors.
    I used a multimeter and started checking the input voltages for the inverter. There is no wire that is pushing over 3.3v. The line that (I think) should be the enable/disable wire reads about 3.3. That wire should be either 0v or 5v (but maybe I am looking at the wrong wire) The wire adjusts analog screen brightness is working correctly 0v to 3.3v.
    I am not sure where pin 1 is, but on one side I will sometimes see the red wire get up to about 1.3v and the blue wire on the other side of the connector is always 0v.
    I know that was a lot in there, but hopefully someone can make sense of it and suggest what needs to be replaced.
  2. .NetRolller 3D
    .NetRolller 3D Notebook Deity
    Connect an external display and use Everest/Aida64 to check if the LCD is being recognized. (Failure to recognize the LCD is a sign of a bad EDID wire in the LVDS cable.)
  3. ditchmagnet
    I know the computer is recognizing the screen since I can still see everything coming up on the screen, the backlight just wont work.
