improve sound quality of virtually any laptop with realtek audio
Discussion in 'Windows OS and Software' started by raclimja, Nov 15, 2010.
Did you notice difference in soundquality?
  1. ZOMG IT IMPROVE MY SOUND QUALITY O.O
    18.8%
  2. nah i didn't notice any difference
    81.3%
  1. booboo12
    booboo12 Notebook Prophet
    I'm stuck with the crappy sigmatel stuff...good work nonetheless though! :D
  2. ViciousXUSMC
    ViciousXUSMC Master Viking NBR Reviewer
    No matter how good your drivers it cant do anything for you if you have poor hardware :D
    Im using the 2.54 drivers the newest ones, but I dont expect much of laptop speakers even a high end model like the Asus G73, my headphones come on and my DAC gets plugged in when its time for any serious listening.
    This bypasses both the hardware and software limitations of a laptop.
  3. weinter
    weinter /dev/null
    This is not true.
    In fact high end laptops comes with better drivers with extra features and driver customisation with 3rd party sound software companies.
    The latest OEM driver from Realtek usually do not come with the extra tweaks so I recommend googling a high end laptop with a Audio Codec similar to the ones found in your laptop.
    Some laptop driver ALC CODEC is found and collected here. Much better than OEM Drivers.
  4. ViciousXUSMC
    The new drivers are just the DRIVERS not the software.
    I still have all the creative xfi software and abilities.
    My point being though that no matter how good your drivers/software it cant make bad hardware suddenly be good. It may help make it sound better but you cant make cheap laptop speakers suddenly be high quality no matter what you do.
  5. weinter
    weinter /dev/null
    Considering the drivers are free, it is good enough.
  6. shakennstirred
    shakennstirred Notebook Evangelist
    i have found that all these so called 3rd party customised dll`s on that site you list are infact in the OEM realtek drivers, i have checked r2.52/r2.53 and the latest r2.54
    so they havent been added by msi/asus or acer to there drivers
  7. weinter
    weinter /dev/null
    Check the download size.
    It means something.
  8. Hayte
    Hayte Notebook Evangelist
    Ok listen up folks. This thing is a suite of post processing effects. You may find that many of the extra dlls are actually similar in function to native VST signal processing tools used by people that make music on their computer except that these ones use the live monitor output as the input. Like VST they will load down your cpu though ow much depends on your native sampling rate, how many of these signal processors you are running simultaneously and how many channels you are affecting.
    Notably, these tools are:
    1) a combination compressor/expander/noise gate (suppresses sudden changes in volume, reduces dynamic range but the corollary of this is that you can turn up the volume higher and not futz out the speakers. Also gates out signal below a predefined threshold.) Note: if you play 2x identical sounds where 1 is very slightly but noticeably louder than the other, most people will pick the louder one as sounding better. Its a weird but consistent listening phenomenon that works up until the loudness becomes discomforting or painful.
    2) Bass Boost. This probably uses some type of fourier analysis to detect the lowest frequency and highest amplitude partial in realtime and then uses an EQ or some sort of resonant filterbank to add a partial one octave below that.
    3) Treble Boost. Hard to tell what this is from their product description but it is more than likely a high shelf EQ and/or a (high) frequency dependent stereo widener.
    4) an EQ. This is a straight up paragraphic EQ which can be quite useful for sound shaping but it also gives you enough flexibility to completely warp the sound you are listening to. For example, you can change the lowest pitch reference, you can filter out all the low and high frequency content leaving only 'telephonic' sound or you can use it to make basically anything sound incredibly unnatural.
    This would be akin to going into custom RGB mode on your monitor. For instance, you may not be happy with the way a picture of the open sea looks so you boost alot of blue to really bring it out. But then you change image to something thats very yellow (like a beach) and it now looks really green because theres too much blue. When you use EQ it has the same effect, it can make something sound a little more sparkly in the treble but then you change songs to something with really loud klangy hihats and the treble becomes unbearable.
    5) a Stereo Widener. This is a simple but clever trick that you can do in audicity manually if you like but which this does in realtime. It delays the left channel a couple of milliseconds after the right channel or vice versa. As you increase the delay you will get a...'rotational' sort of effect and an exaggerated sense that the sound is coming from the far left and right at the same time. Increase the delay enough and eventually one channel will be perceived as an echo of the other.
    This can exaggerate stereo effects and make them sound cooler but it wrecks mono compatibility because of destructive phasing.
    6) 'Maxx Dialog'. This is a weird one. It looks like it takes a stereo pair and sums both to mono. Then it remixes this back into the original stereo pair and gives you gain control. I'm not sure what to make of that but if you think it makes things sound better then fair enough.
    Conclusion:
    What these tools do is give you some control over the auditory illusion that the sound is trying to present. However, at some point it is important to realise that that the engineer/producer recorded and mixed the audio a certain way and that it was a deliberate, creative decision. Therefore, it is just as easy to defeat the illusion as it is to enhance it. Now theres no harm in trying to squeeze a little bit more bass out of tiny speakers and these tools let you do that though that too is something of an illusion because the woofers will be so small that they won't be able to produce low bass with linearity anyway.
    That said, what counts is your enjoyment and that will subjectively vary from person to person. I would like to point out though that the absolute biggest improvement the average person can do for sound quality is to simply buy bigger and better built speakers and to listen to them in an environment that sounds pleasant. Everything else is more or less irrelevant to a point and that point almost certainly will not concern consumers (i.e. you won't be buying soundcards for the amount of simultaneous audio and MIDI I/O they can provide).
  9. weinter
    weinter /dev/null
    Yea I agree
    On those custom drivers certain low pitch notes sounded terrible but overall I still think it sounded much better.
    Thanks for the info :)
  10. reg767
    reg767 Notebook Geek
