Ideal CPU for VR
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Penchaud, Apr 27, 2020.
  1. Penchaud
    Penchaud Notebook Consultant
    Hello,
    I hope you guys can help.
    So my kid wants an oculus rift and im looking at the minimum specs and it says as a minimum it needs a AMD Ryzen 3 1200. The kid has a 7th Gen A10 9700 APU
    So looking at the two CPU side by side the kid’s base clock is 3.5GHz quad core, whereas the minimum recommended Ryzen 3 has a base clock of 3.1Ghz quad core. So that says to me that the kid’s CPU is “better”, however looking at benchmarking side by sides, the Ryzen 3 performs better so im a little confused as to whether the kid’s cpu is considered better than a ryzen 3 or not..
    You guys have any opinion?
  2. senso
    senso Notebook Deity
    The APU is still based on Piledriver/Bulldozer arch, its a pretty crappy arch, and a Ryzen sure kicks it ass, even with much lower clocks, and if you want VR you will need a dedicated GPU, so, drop the APU and get a better CPU, what is the current motherboard so we can help you about what CPU's can it run.
  3. Penchaud
    Hi Senso,
    Asus Prime A320M-K
    Only got 4Gb Ram in it too so you're right, I need more ram and a GPU in there too
  4. senso
  5. Penchaud
    So for clarification: I can use the existing Motherboard with a new Ryzen 5 CPU, but it needs a BIOS update to support it?
    Cheers for you help! Things were so much simpler when I was younger.. All I needed to do was check if it was socket 7 then the Mhz of the processor was the deciding factor lol
