IdeaFan for y510p y500 G500 Y580 y410p
Discussion in 'Lenovo' started by allstone, Sep 27, 2016.
  1. GTMoraes
    GTMoraes Notebook Consultant
    Hmm.. using this actually worsened my temperatures. It seems that the brief moment the fan stops actually causes the heatsink to accumulate too much heat, and the subsequent fan blast (dust mode) isn't enough to take it all out.
    Playing Witcher 3 with this, I'd game at around 90 celsius, with bursts to 93 when fan stops, while without it, it'd be at around 85~87. I set Ideafan to start at 80 Celsius
    Maybe if I set the auto interval to something like 85 or 86 celsius, it'd just give the initial fan blast to hold it below 85, then it would return to normal mode... I'll be trying this
    allstone likes this.
  2. allstone
    allstone Newbie
    Just thought Id give an update to OpenHardwareMonitor for sensor data and also some bugfixes to show temps. Here you go: IdeaFan 2.0
    GTMoraes likes this.
  3. GTMoraes
    Thanks for the update. The pause interval seems to be pretty good for maintaining an average high fan speed.
    I've actually resorted to hardware modding and added a thermal fuse that disconnects the PWM cable when it goes over 85°C. Disconnecting the PWM cable makes it go 100% until below 85°C.
    However, if the fuse keeps open for a long time (+5 min), the fan controller will ignore the fans when it regains control, and will keep the fans OFF, no matter the temperature. This leads to a very bad situation that it keeps hitting 85-90 at idle.
    Running IdeaFan fan blow mode resets the controller and makes it work again. It's a life saver for me.
    Just out of curiosity, this is on an Ideapad 320, and still works just fine. Maybe it works on all Lenovo line.
    intruder16 likes this.
  4. Velox Segnis
    Velox Segnis Newbie
    Signed up for these forums to stop by and say I've been using your program for a few years now and it's greatly extended the usability of my y510p. Without this, most games would be literally unplayable.
  5. allstone
    allstone Newbie
    thanks, Velox. I use it every day too! I even play on Oculus with Virtual Desktop so my computer sits further from me and no hassle to run IdeaFan. So far its working great with no damage to the fans in all the years I was using it :)
