IC Graphite Thermal Pad Available for Test and Review
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Innovation cooling, Apr 9, 2018.
  1. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    I actually just checked the pad, pressure is not a problem, I used a sheet larger than the die to see if it would leave an imprint, and it sure did, the sheet is nicely pressed in where the CPU would normally be. I'm not sure if paste would help this, I haven't seen any evidence here to prove so
  2. jclausius
    jclausius Notebook Virtuoso
  3. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Arrrrbol, Papusan and jclausius like this.
  4. illuMinniti
    illuMinniti Notebook Evangelist
    So you applied LM or did you use some kind of paste? And you saw worthwhile temp decreasing? I'm thinking up upgrading my Alienware laptop and may try one of those graphite pads if I can find it equal/better than kryonaut. Most pages I found seem to have compared the IC graphite to IC Diamond LM
  5. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    You seem to be very confused. I had liquid ultra on before the pad, tried ic graphite, it sucked compared to liquid ultra, so I went back. Graphite pad is not better than phobya nanogrease extreme or kryonaut. IC diamond does not make liquid metal TIM, only IC Diamond paste and IC graphite pad.
    My preference has been, and continues to be, liquid ultra.
    Arrrrbol, illuMinniti and Papusan like this.
  6. amirbahalegharn
    amirbahalegharn Notebook Consultant
  7. slim shady
    slim shady Notebook Enthusiast
    By the gods after going through the entire thread my head is :wacko:.But in conclusion (feel free to correct me) the soft pgs pad is **** even with good contact, works as a good sandwich between lm and better to go with with lm or phobya / gelid.
    On the off note: what has been the better or best traditional paste after all this time + the best lm ? Why i ask is there is a lot of different opinions and would like to hear from experts.@Mr. Fox,@Papusan
    P.S in simple terms is the soft pgs pad good enough to replace traditional tim ?
  8. jclausius
    I think the conclusion drawn in this thread is that in general it cannot make enough contact to replace those TIMs.
    Papusan likes this.
  9. slim shady
    edit : delete
  10. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Update on this, attempted to install 2 x pads on my PlayStation 3, they were next to useless as the heatsink does not exert enough force on the pads. Triggered overheat warning within 5 minutes of idling. Really too bad, I would have loved solid state thermal interface for the pesky PS3 CECHA01
    interestingly enough, DECR-1000A (the official PS3 reference tool that developers used) actually used pyrolytic carbon pads straight from the factory, very similar to this stuff. I would imagine since DECRs are only made in Japan, the pads themselves were probably sourced from Panasonic.
    Papusan, Vasudev and hmscott like this.
